Navigation & Audio Tweeter replacement?
Old Nov 21, 2008 | 08:21 PM
Z06C5R's Avatar
Z06C5R
So I had spend some time in my old 944 last week while I gave the MINI some time off daily duty to rest her faulty ball-joint, and it sort of turned into an interesting comparison of stereo equipment... The 944 has a very nice Polk system that I installed myself, and I have always found to be extraordinarily accurate when fed good source. The one letdown is that it's a self-installed system that doesn't have the advanced acoustical tuning of a factory system. Now that I'm back in the MINI, I'm feeling that the clarity of the highs is not quite where it could be...
I'm all for the idea of popping in a higher-end tweeter, but I don't want to destroy the very good acoustical tuning that the H/K system seems to have either. Has anyone had any success with aftermarket tweeters?
Old Nov 22, 2008 | 09:33 AM
nabeshin's Avatar
nabeshin
Functioning Lunatic
I don't have the HK system, but I would guess that it does not have any kind of crossover circuitry. The standard system uses a small resistor attached to the tweeter to limit the watts, or noise, or something like that. If you were to just replace the tweeters, it would no longer have that resistor. That could cause damage or distortion to the new tweeter as it tries to play frequencies outside it's range.
Basically, if you replace a tweeter, make sure you have crossover circuitry.
Old Nov 22, 2008 | 03:54 PM
Z06C5R's Avatar
Z06C5R
Indeed. They typically come with a basic crossover to avoid the damage you mentioned.
eliseo1981
Jan 28, 2021 02:45 PM
woodstudio
Mar 15, 2020 08:28 AM
silence2-38554
98
Sep 21, 2016 02:52 PM
Knuckle14
Aug 26, 2015 08:10 PM
JPMontes3
Aug 23, 2015 01:26 AM
