Coolant tank leak on my MC...
Old Sep 19, 2003 | 03:47 PM
antsmini's Avatar
antsmini
I took my car to Prestige because the coolant turned brown.... They flushed the system and replaced the coolant. Not sure if they replaced the tank...but now I have a leak. My overflow tank is at maximum and there is whitle junk coming from the seam on the coolant tank, as well as on the rubber lining and heat shield below it. I didnt think coolant leaks existed on the MC, only the MCS. I guess its offical now, I have had every thing that can go wrong with this car, go wrong.
Old Sep 19, 2003 | 04:16 PM
dkstone's Avatar
dkstone
Time to execute on the lemon law, should have kept your first MC all the problems were taken care of.
Old Sep 19, 2003 | 04:33 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Yes you have a leak it sounds like from the chaulky light brown yellow dried residue around and under your bottle.
The MCS is famous for leaks in the early bottles. I had mine replaced once in June and no more trouble. Your MC bottle is different design so it might be fine to just replace it. See your service manager. Good luck and I hope you do well with the fix- I did.
Old Sep 19, 2003 | 04:36 PM
Thechandler81's Avatar
Thechandler81
That really sucks ants! I hope to god your cars bad luck is not contagus.
shorenetworks
Nov 4, 2019 06:18 PM
debitsandcredits
Sep 21, 2015 08:34 AM
Mb460
Sep 14, 2015 05:50 AM
Sep 10, 2015 03:36 PM
mimaal
Sep 4, 2015 09:09 AM
