Falken 215/45 16 RT615 on 6.5" wide wheel
Old Nov 11, 2008 | 10:53 AM
fjork_duf's Avatar
fjork_duf
So I was putting my autox wheels on my car this weekend and I noticed a message on my tire that reads "Do not mount on 6.5 inch wheels"
Well.... unfortunately I didn't heed this warning and have already mounted those tires on 6.5in wheels. I did some research and went on the advice of some people in the forums. I just confirmed with falken's site that the tire I'm using is only recommended for 7"-8" tires. With that said, I've run probably about 8 autoxes on this wheel/tire combo without any noticeable issues.
Is anyone an expert on tires/wheels here that can explain why my combo would be ok, or if not why I should mount different tires?
Bonus question: I am considering some V710s for next season. Will the 225/50ZR16's fit the 16x6.5 wheels? Any rubbing?
Thanks in advance.
Old Nov 11, 2008 | 10:58 AM
txwerks's Avatar
txwerks
Did the message say, "Don't mount on a 16.5" rim"? I've never seen a tire with a "Don't mount on an X.X wide rim"...
I used to run 225/50R15 Michelin Pilot Sport Cups on a 15x6.5" rim... As long as you have the right offset, it works...
Old Nov 11, 2008 | 11:26 AM
cube17576's Avatar
cube17576
Coordinator :: STLMini
Most AutoX'ers run 215/40/16 V710s on the factory 6.5" wheel. It is a little tricky to squeeze them on (and not all shops will), but as long as the seat then you are fine.
Old Nov 11, 2008 | 12:52 PM
leo@edgeracing.com's Avatar
leo@edgeracing.com
The message on the label is for wheel that are 16.5". It has nothing to do with the width. That series tire should not be mounted on a 16x6.5 because Falken only recommends a 7" to 8" width wheel. I would be careful because that tire could unseat.
Leo
leo@edgeracing.com
800-489-5353 x211
http://www.edgeracing.com
Old Nov 11, 2008 | 04:15 PM
fjork_duf's Avatar
fjork_duf
http://www.kumhousa.com/print_specs.jsp?pid=EV710
From Kumho's site:
215/40R16 82W 7.0 - 8.5 22.8 8.6 on 7.5 4 30/C/A 18.2
They do not recommend a 6.5" wheel. I recall most people with 16 inch wheels run 225/50 V710s... is this incorrect?
Old Nov 11, 2008 | 07:38 PM
RedSkunk's Avatar
RedSkunk
Manufacturer recommendations are often at odds with the actual application. A 215/45 fits fine on a 6.5", and yes, people run 225s on 6.5" wheels. I wouldn't sweat it for a second, myself.
Colt45Magnus
Sep 7, 2015 10:47 PM
Aug 25, 2015 12:58 PM
AdrenaliNate
Aug 24, 2015 12:37 PM
Aug 21, 2015 02:29 PM
Aug 21, 2015 11:25 AM
