R56 Torque Specifications
Old Nov 8, 2008 | 09:49 AM
shagerman's Avatar
shagerman
I have a 2008 Mini Cooper Hatchback. It's not possible to have my Mini services regularly by a dealer based on where I live. That been said, does anyone know the torque specs for the oil filter cannister, the drain plug and the lug nuts?
I've looked but am not having much luck.
On a related note, does anyone know how to reset the oil setting? I haven't had any luck on that one either.
Old Nov 8, 2008 | 10:15 AM
NashvilleMiniStan's Avatar
NashvilleMiniStan
The first issue of Alliance has pictures and torque spec. Hope that helps.
https://www.northamericanmotoring.com/alliance
Old Nov 8, 2008 | 12:39 PM
rburna's Avatar
rburna
i have an 07 cooper S, so im not sure if the torque is the same as a non S model, but on the filter cap it says 25 ft-lbs.
did you grab a few oem filters from the dealer? if not, i dont know if the after market ones come with a new ring seal for the cap itself. dont forget to oil the ring as well to seal it properly
Old Nov 8, 2008 | 01:07 PM
MrTIer's Avatar
MrTIer
In summary:
18.5 ft/lb on Filter Canister (27mm or 1-1/16 socket)
22 ft/lb for drain plug (8mm Hex Allen Wrench)
4.5 quarts of oil with a filter change
103 ft/lbs on the lug nuts.
navybsn
Oct 5, 2018 04:42 PM
pglgp1292
Aug 9, 2017 12:45 PM
MGBill1186
Oct 2, 2015 06:54 AM
Tires, Wheels & Brakes
Oct 1, 2015 10:38 AM
Oct 1, 2015 10:17 AM
