Will the Brembo 12.6 fit under S-Lites?
Old Nov 4, 2008 | 01:59 AM
Poppa Bear's Avatar
Poppa Bear
I've searched around and found this thread listing compatible BBKs and this thread asking about S-Lites, however, I've not found a solid answer, one way or another, if the Brembo 12.6 would fit under the 17" S-Lites. I would appreciate any help ya'll could give.
Cheers!!
Old Nov 4, 2008 | 04:04 AM
PGT's Avatar
PGT
I don't think so.
Old Nov 4, 2008 | 06:01 AM
drsilvermini's Avatar
drsilvermini
Send mini mania an email asking them and they will let you know
Old Nov 4, 2008 | 07:34 PM
toddtce's Avatar
toddtce
I do not know of any BBK that fits under these wheels. The only possibility I can think of would be my "Caliper Kit" where you retain the stock rotor. The size of my DP6 caliper fit to the stock rotor is nearly the same body overhang. Given that most full on BBK use both larger rotors and larger calipers...it's not going to happen for you.
Old Nov 5, 2008 | 04:21 AM
Poppa Bear's Avatar
Poppa Bear
So, I'm guessing that only the JCW kit would fit then?
Cheers!!
Old Nov 5, 2008 | 05:01 AM
PGT's Avatar
PGT
JCW yes. It's a very capable kit with proper brake balance compared to just adding a BBK, especially for the street. Those who do the occasional DE won't be disappointed either.
Old Nov 5, 2008 | 05:46 AM
toddtce's Avatar
toddtce
You could also consider the Caliper kit as mentioned but add your own "late JCW" rotors giving you the larger rotor you may want as well as the muliti piston design of the common BBK. I don't personally sell the larger oem rotor (I believe that is 320mm?) but it is an option.
Old Nov 5, 2008 | 06:11 AM
PGT's Avatar
PGT
I have a spare lightly used set of JCW/R56 rotors left over from my car.
bjcarter2
Aug 31, 2015 04:03 PM
Aug 12, 2015 01:24 PM
holkki
Factory JCW Talk (2009+)
Aug 12, 2015 10:14 AM
