R50/53 Former Rover Engineer on new MINI Development
Old Nov 1, 2008 | 11:58 AM
Mab01uk's Avatar
Mab01uk
This 'Insider' article posted below found in an old issue of the UK "CAR" magazine from July 2001 makes interesting reading................... 'a former Rover engineer tells at first hand the role Rover had to play in the development of the new MINI' :
New MINI: more cool Britannia than BMW will admit?
A Former engineer is furious at BMW’s claims that Rover had no involvement in the new Mini. It was, he claims, a very British affair.
Robin Ford doesn’t fit the stereotypical image of the British automotive engineer. He’s well spoken, articulate… and pretty fed up. Within hours of the last issue of CAR magazine hitting the streets, Ford had e-mailed us in anger at BMW’s claims that ‘Rover hadn’t been much help’ in designing and engineering the new Mini, especially in terms of the unique front-drive chassis.
‘That made my blood boil’ exclaims Ford. ‘The brief from BMW was for a MacPherson strut front and Z-axle rear-axle layout. That was it. There are no BMW components in the systems and they were entirely designed at Rover’s Gaydon engineering centre in Warwickshire. The geometry, component stiffness, durability, compliances – all were specified and designed by Rover engineers’.
Ford says he should know, because he was the front-axle system engineer responsible for the packaging, design and integration of the Mini chassis. ‘When we started, very little was defined. BMW didn’t ask for any BMW components, it let us go away and get on with it.
‘Even the Mini’s engine and transmission was engineered at Longbridge and Gaydon. The engine was worked on at Powertrain, who also did the gearbox, which is based on the unit used by Rover. The Cooper S uses a Getrag box, but the development was carried out at Longbridge. I’d say there were hundreds of British engineers on Mini, maybe as many as 300 or 400’.
From the outset, Ford reveals that it was Rover employees who turned BMW’s vision into reality. ‘We started development with simulators. There were two types: Rover 200s with a mock Mini chassis and 200s with the Mini’s Pentagon engine. The supercharged K-series simulator was a cracking car. In the end, over 200 simulators were built at Longbridge and we learnt a lot. The idea was to get the design to what’s called ‘production release’ a year or so before the Mini was due to go on sale. The Mini concept car the press saw at the Frankfurt show was built in summer 1997, with glassfibre panels taken straight off the clay styling model and then fitted to a Punto chassis. (See Video Below)
‘We knew what the Mini had to be – the best handling front drive car in the world. We were very happy with a Z-axle concept, although it’s not great for space. Some people also argued for double wishbones at the front, but BMW insisted that the Mini was a BMW and had to have struts. However, it wasn’t easy to make the front suspension work. The Mini has a very compact front end.
‘We worked very hard to minimise torque steer and the complexity and detail work in the chassis is on a much higher level than under a Puma or Lupo. Success has a lot to do with component stiffness. For example, the Mini has a two piece box section chassis arm with 1.5 metres of welding in it. The flex in the suspension components is less than 10 percent of that in the bushes. The stiffness of the mounting points is good for NVH’.
Ford says he is proudest of the Mini’s steering system because, he claims, he was responsible for changing the system late in the day. ‘Up until 1999, the Mini’s steering was fully electric with a powered worm-drive. But it was almost surreal: there was no kick-back or feedback. On rutted roads you couldn’t feel anything, even at the limit of adhesion. I had overall responsibility for the whole front end and didn’t like it.
‘The steering department said it could be fixed with a tweak to the steering, so BMW told us to get it sorted. But instead I knocked together a simulator with an electro-hydraulic Rover 25 rack. The original simulator had a Ford Escort rack modified for the right geometry and it felt good, but BMW drove both and chose mine. Fully electric steering was a pet project at Rover and several engineers had tried it in a Mondeo, where it worked well. It was just inappropriate in a Mini – there was no joy.
‘It was very hard to package a steering pump on the Mini engine. It’s extraordinarily tight under the bonnet. We had to re-write the rule book on tyre and component clearances. In fact we threw the rule book away. There’s meant to be 15mm clearance for tyres. Now there is actually a benign foul in extreme circumstances. It was a packaging nightmare – or miracle – and only got done thanks to computer-aided design. We needed a lot of suspension travel to cope with bumps and the 17 inch wheels on the Cooper S were an absolute nightmare to accommodate. I think the sweetest handling Mini was one with smallest tyres – it’s a pity the run-flat tyres were added late in the day’.
Robin Ford’s involvement with the Mini came to an abrupt end in early 2000 when BMW suddenly asked for the Mini computer files to be hurriedly downloaded to German hard drives. ‘BMW had finished the assembly building at Longbridge and wanted to ramp up production for a January 2001 on-sale date. It all looked fantastic when we went to a BMW pep talk in February 2000 explaining what they were going to do. The old dyed-in-the-wool Rover people were sceptical but I was taken in’. By mid March BMW’s board announced it’s intention to dispose of Rover and Ford left the project.
Now running his own sports car manufacturer, FBS, Ford looks back on Mini as ‘a project apart. Some at Rover thought all the effort and money that went into Mini was a distraction from the main job at Rover’. And they might be right.
Edited by Paul Horrell and Hilton Holloway (CAR July 2001)
"Rover" MINI Prototype Frankfurt Preview video 1997
http://www.youtube.com/watch?v=Is-9aI7utFQ
Old Nov 1, 2008 | 12:05 PM
Dr Obnxs's Avatar
Dr Obnxs
Interesting read...
thanks for sharing...
Matt
Old Nov 1, 2008 | 12:50 PM
MCLeonard's Avatar
MCLeonard
Very interesting article. Sounds like BMW politics led to rewriting of the history.
I found this comment especially interesting given how so many people like large wheels and low profile tires.
'We needed a lot of suspension travel to cope with bumps and the 17 inch wheels on the Cooper S were an absolute nightmare to accommodate. I think the sweetest handling Mini was one with smallest tyres'
iggi
18
Feb 9, 2026 01:00 AM
TREX
Nov 2, 2019 07:31 PM
Aug 10, 2015 02:03 PM
Aug 10, 2015 01:59 PM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
