R50/53 Caps for front strut towers
Old Oct 27, 2008 | 12:19 PM
JIM_GRAHAM's Avatar
JIM_GRAHAM
I saw some guy selling black plastic caps for the 2 1/2 holes in the top of the front strut towers for $8 per set. After reading that the "Spiffy" Caps for the front doors could be purchased at Lowes for around a dollar I figured there must be s ource for the 2 1/2 caps.
I found a place:
http://www.harmancorp.com/products/p...tyleplugs.aspx
I filled out a form on-line and got two "free samples" sent to me and they fit great. I doubt I will be buying the box of 1000, unless I want to compete with the guy with the $8.00 set!
Old Oct 27, 2008 | 06:03 PM
Minidrivr's Avatar
Minidrivr
Nice find. Was there a shipping fee involved?
Old Oct 27, 2008 | 06:46 PM
OldRick's Avatar
OldRick
You could also buy a hundred or two from http://www.mcmaster.com
Search for "finishing plug" - choice of nylon or polyethylene styles
Old Oct 28, 2008 | 03:24 AM
JIM_GRAHAM's Avatar
JIM_GRAHAM
They shipped them to me for free.
I did have them shipped to my work, not my home. Listed my business name.
Old Oct 28, 2008 | 04:12 AM
Kirkz24's Avatar
Kirkz24
Now lets see them on the car! Id love to see a picture!
Old Oct 28, 2008 | 08:35 AM
JIM_GRAHAM's Avatar
JIM_GRAHAM
This site sells small quantities. 50 of the caps that I got for $8.18 + shipping. They have another cap (Locking unvented) for $11.45 for 25. I do not know if the locking cap will easily be removed without destroying it. The other one comes out easily.
Pics to follow.
Old Oct 28, 2008 | 09:15 AM
OldRick's Avatar
OldRick
The Poly caps are easily removed - the nylon ones will cause you to scratch the paint around them when attempting to remove them (don't ask how I know this).
The Poly caps also look better, IMHO - lower profile and a nice edge around them.
Old Oct 28, 2008 | 02:38 PM
JIM_GRAHAM's Avatar
JIM_GRAHAM
They are easy to remove if you need to get under it.
Attached Thumbnails Caps for front strut towers-nocap.jpg   Caps for front strut towers-withcap.jpg
Old Oct 28, 2008 | 06:48 PM
Kirkz24's Avatar
Kirkz24
Having these, would it conflict with strut tower braces? It looks great!
Just adds that extra touch that is missing.
Old Oct 28, 2008 | 07:15 PM
OldRick's Avatar
OldRick
I've had them on with OMP and IE braces - no conflict, as the caps just cover a couple of mm of the dome outside the hole.
Old Feb 7, 2009 | 04:44 PM
Minidrivr's Avatar
Minidrivr
I just got my two free samples today. Ordered on the 4th. Fit and finish look great. The caps are flexible enough they won't damage the paint.
Old Feb 7, 2009 | 06:15 PM
iwashmycar's Avatar
iwashmycar
ordered! thanks!
Old Feb 7, 2009 | 06:45 PM
lhoboy's Avatar
lhoboy
I found a place:
Thanks for the outstanding lead. They're going to start wondering why they're getting hundreds of sample requests for the same exact cap.
We may have to do a group buy if they catch on.
Old Feb 8, 2009 | 05:35 AM
JIM_GRAHAM's Avatar
JIM_GRAHAM
My caps kept on popping out and I eventually lost one. I think it might be some type of air pressure increase in the void under the cap that takes place when the shock compresses. I suggest you put some small daps of black silicone rubber in the grooves before installing them. They can still be removed.
Old Feb 8, 2009 | 06:03 AM
lhoboy's Avatar
lhoboy
I thought that was from the impact of hitting pot holes. If it is truly air pressure doing it, then a small hole drilled into the top of the cap should eliminate the problem.
Old Feb 8, 2009 | 06:41 AM
Fatherdeth's Avatar
Fatherdeth
Note****If you are running Ireland Engineering fixed camber plates or any type of adjustable camber plate, a portion of the material under the cap will have to be trimmed away on one side to allow the cap to sit flush.
Old Feb 9, 2009 | 06:20 AM
iwashmycar's Avatar
iwashmycar
NOTE....they're going to call you based on the amount of requests they are getting,,,,Make a good excuse.... or maybe the truth? dunno if theyll like that
Old Feb 9, 2009 | 07:47 AM
maurola's Avatar
maurola
Hey Guys...got a call from Harman this morning asking about my request for the caps...they said they have had a lot of requests in the last 2 days for the same exact item...I made up some tale about why I wanted to try them so they are looking at each request now...they want 176.00 per 1000, that's there smallest order...good news travels fast, huh
Old Feb 9, 2009 | 09:41 AM
Kirkz24's Avatar
Kirkz24
I guess I did a good thing asking for some a few months ago!
Now all im missing is the Mini
Geeze, cant wait for June!
Old Feb 9, 2009 | 09:44 AM
OldRick's Avatar
OldRick
The poly caps fit fine on my IE Fixed camber plates. No reason to trim anything. www.mcmaster.com sells them by the hundred.
Correction: McMaster-Carr sells them in 50's for about $10. Search for plastic hole plugs
Old Feb 9, 2009 | 10:03 AM
Fatherdeth's Avatar
Fatherdeth
Well, you obviously have a different brand then. I had to trim mine.
Old Feb 9, 2009 | 01:37 PM
lhoboy's Avatar
lhoboy
What's so special about June?
Old Feb 9, 2009 | 04:07 PM
Kirkz24's Avatar
Kirkz24
My lease will be up with my current car. (Mazda 3 GT)
Im slowly collecting stuff for my Mini so when I get it I can get some little mods done to it. Im still on the look out for some S Lites.
Old Feb 9, 2009 | 04:14 PM
iwashmycar's Avatar
iwashmycar
ive got 3 crown spokes... just thought id throw that out there lol
Old Feb 9, 2009 | 07:25 PM
Kirkz24's Avatar
Kirkz24
Just need 1 more Hehe.
Im actually trying to find them here in Canada before resorting to purchasing them in the states. Alot less trouble with customs and all.
