R50/53 '03 MCS 60K miles, Engine dies at high rpm
Old Oct 26, 2008 | 07:26 AM
SeanKidd's Avatar
SeanKidd
Strange problem just started occuring, Trying to pass a truck, downshifted and gunned it, revs crept to over 5K but under redline, engine shuts down and needs to turn key off and restarts fine, while slowely decelerating. Replaced fuel filter (pia), plugs, sc belt and IC bellows (somewhat loose). Check engine light resets after 3 starts. Stock pulley. This has happened 5 times and is repeatable. Can any code reader get a code that can be translated to BMW? or is this a trip to dealership (Prestige or Morristown?)
Please help!
Old Oct 26, 2008 | 02:50 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Any Autozone or similar parts stores can read the ECU codes for free. Then come back the boards with those numbers and those who have the Bentley manual can look them up.
Old Oct 26, 2008 | 04:54 PM
Rich.Wolfson's Avatar
Rich.Wolfson
Originally Posted by SeanKidd
... pass a truck, downshifted and gunned it, revs crept to over 5K but under redline, engine shuts down ...
You have a bad Bypass Valve. It is common and, as I have said before, I am thinking there are a lot of '03s-05s with the problem but it remains unknown as the drivers of those cars rarely if ever gun it.
Now I'll stand back as the DT valve vs OEM discussion begins.
Rich
Old Oct 26, 2008 | 06:25 PM
Eurothrasher's Avatar
Eurothrasher
Can he get all of the codes from Autozone's and alike ?
For some reason I was under the impression that BMW/MINI held back on releasing some code data ?
Old Oct 26, 2008 | 11:42 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
They can read the "check engine light" and get the P9999 codes, which then can be looked up. I know that I've always been able to get these codes when my local Autozone hooked up their tool.
Old Oct 27, 2008 | 03:58 AM
SeanKidd's Avatar
SeanKidd
Thanks for the suggestions, I've heard the bypass was tough to change.
iggi
18
Feb 9, 2026 01:00 AM
09R56
Nov 16, 2022 10:49 AM
Svejk
Feb 24, 2019 12:18 PM
wind715
Aug 11, 2015 07:56 AM
