Drive Shaft or Motor Mount
Old Oct 24, 2008 | 10:36 AM
jtack's Avatar
jtack
Ok, I have a ticking or clicking sound when taking off. One click and thats it. Most of the time while taking off its there but occasionally it does not happen. I think from my research I have norrowed it down to the drivers side drive shaft or the drivers side motor mount. How can I check for a bad motor mount. What are the consequences of driving around with a bad driveshaft and or a bad motor mount.
Old Oct 24, 2008 | 11:03 AM
zeus7625's Avatar
zeus7625
From: So far south in AL, one more step and I'm swimming (in oil)
My MC turned up with a bad driveshaft just before I sold it. I was feeling a vibration in the steering wheel over smooth roads. I thought I had tire problems but my mechanic helped me diagnose it by 1) rotating the tires to see if the vibration followed and then 2) realizing whether the vibration was during acceleration and / or coasting. The vibration did not follow the tire rotation and it was felt only during accelaration. Purchased and installed a new driveshaft and the vibration disappeared.
Continuing to drive on a bad driveshaft may caused additional problems in the transmission or wheel bearings if the vibrations gets too great.
I can't help with the motor mount troubleshoot.
Good luck,
Old Oct 24, 2008 | 01:13 PM
03BRG's Avatar
03BRG
Try doing a search on axle nut being loose. Kind of a known problem and a easy fix
Old Oct 24, 2008 | 02:59 PM
Yo'sDad's Avatar
Yo'sDad
It is the outer CV joint. If it will click for the dealer and under warranty, they will replace it.
YD
Old Oct 24, 2008 | 10:16 PM
guidmini's Avatar
guidmini
click this!
JT its the axleshaft nut. I retorqued them weekly. Mini's come in for this.
9 out of 10 its the nutss. Some times its the RF engine mount. Open the hood see if the mount is puking black hydraulic fluid. I had one the other day
.Damn click noise turned out to be the axle nut and the engine mount.
Hope this help
Guido Cert tech BMW/Mini/Mercedes
Old Oct 25, 2008 | 05:04 PM
jtack's Avatar
jtack
Thank you all for your input!!
Where do I find this axel nut and how easy it for me to tighten myself. My car is out of warranty
Old Oct 25, 2008 | 05:55 PM
Crashton's Avatar
Crashton
My MINI was exhibiting the same symptoms as yours. I metallic clicking sound on the left side when setting out in first gear. Not all of the time, but most of the time. The dealer installed a new driveshaft. Sound was now gone with that fix.
Fast forward 2,000 miles. Now it was doing it again, same thing. Back to the dealer, now they have replaced the left front wheel bearing. Sound is gone with his second fix. Time will tell if it is truly fixed this time. Fingers crossed...
Old Oct 25, 2008 | 06:23 PM
Yo'sDad's Avatar
Yo'sDad
I had the click, like two pool ***** hitting together. New axle and click gone. I tightened my axle nuts several times and it never did make any difference.
YD
Old Oct 29, 2008 | 07:02 AM
jtack's Avatar
jtack
Is this nut everyone is talking about tightening behind the center cap of the wheel on the hub?
Old Oct 29, 2008 | 08:00 AM
wewantamini's Avatar
wewantamini
Yes
Old Oct 29, 2008 | 09:57 AM
Wookie's Avatar
Wookie
What's the correct torque for the axle nut? And this may be a dumb question but what's the best way to remove the cap to access said nut?
Old Oct 30, 2008 | 12:50 PM
1FSTMINI's Avatar
1FSTMINI
you can see it when you take the wheel off. you will see it located in the middle of the rotor
182nm. the nut should be replaced when doing the shaft
Old Nov 2, 2008 | 01:49 AM
07BPB's Avatar
07BPB
Just letting you know I had an issue like this. Occasionally when taking off in first gear, or braking I would hear a single tap come from around the wheel area. Did this for two days, and nothing was wrong with the steering at all. Driving home one day the car shook like crazy, pulled over and the wheel was very loose. Tightened it up and problem solved.
Old Nov 6, 2008 | 06:42 AM
jtack's Avatar
jtack
What size is the axle nut on the outside of the rotor?
DixonL2
Apr 13, 2021 08:05 AM
Gil-galad
Eastern Iowa MINIs
63
Nov 17, 2016 02:54 PM
tr3y003
Oct 22, 2015 10:48 AM
JPMontes3
Aug 23, 2015 01:26 AM
minipopkart
Aug 13, 2015 05:22 AM
