2nd gen wheels???
Old Oct 22, 2008 | 10:12 AM
snss3's Avatar
snss3
2nd gen wheels???
Would you know if the 15" 2nd gen mini wheels/rims would fit on a 1st gen mini. Thanks
Shawn
Old Oct 22, 2008 | 11:12 AM
ScottRiqui's Avatar
ScottRiqui
Yes, they'll fit, as long as the 1st-gen car doesn't have the JCW brakes.
All of the OEM MINI wheels from the very beginning have the same bolt hole spacing and bolt hole diameter, along with the same hub diameter, so they're interchangeable.
The only problem you can run into is that the 2nd-generation R56/R55 'S' brakes are the same size as the 1st-gen JCW brakes, so none of the 15" OEM wheels and quite a few of the OEM 16" wheels won't fit over the new 'S' brakes (or the new JCW brakes, obviously).
Old Oct 22, 2008 | 02:03 PM
snss3's Avatar
snss3
Thanks for the quick response.
Old Oct 22, 2008 | 03:22 PM
tekron's Avatar
tekron
I would do a double check on this because when I was ordering after market wheels I had to make sure when my car was made (it was a late 06 model so they were transitioning to the 07s) and apparently the lug sizes or something were larger so just do your homework on this..
Old Oct 22, 2008 | 03:33 PM
hunter99's Avatar
hunter99
After 7/06 the bolt diameter went from 12mm to 14mm. All the newer '07 up MINI's use the larger diameter.
Old Oct 22, 2008 | 03:46 PM
ScottRiqui's Avatar
ScottRiqui
Yes, that's a good thing to check before buying aftermarket wheels, but all OEM MINI wheels from the beginning have had ~16 mm bolt holes, so they'll work with either the older 12 mm bolts or the newer 14 mm bolts.
Old Oct 22, 2008 | 03:53 PM
tekron's Avatar
tekron
I was referring to what Hunter was saying but yeah..
Old Jul 24, 2010 | 09:43 AM
3leafz's Avatar
3leafz
what about BBS R90 anthracite? did they make any changes to the lug bore size for the 1st and 2nd generation mini's?
and is BBS considered an aftermarket brand?
-calvin
Old Jul 24, 2010 | 12:32 PM
ScottRiqui's Avatar
ScottRiqui
The R90 lug bore has remained unchanged, so it will also work with either 1st or 2nd gen cars.
And the R90 by BBS is still an OEM wheel. OEM just means "Original Equipment Manufacturer", and in the case of the R90 the OEM is BBS. I'm pretty sure *all* of the MINI wheels are made by someone else.
Old Jul 24, 2010 | 12:52 PM
Oxybluecoop's Avatar
Oxybluecoop
The R90,R98 and R109 are all manufactured by BBS.
woodstudio
Mar 15, 2020 08:28 AM
gundesen
Nov 19, 2015 07:33 PM
tacticalbacon02
Aug 22, 2015 06:05 PM
vballkid77
Cooper (non S)
Aug 10, 2015 04:44 PM
