R50/53 Rocking front seat
Old Oct 21, 2008 | 03:05 PM
idickers's Avatar
idickers
Rocking front seat
The front driver's seat in our 2002 MCS has started to rock lately, and tonight on the way home both front legs of the seat came loose. I can't find anything in my Bentley manual about attaching the seat, but I'm assuming there is a bolt or torx at each corner. Can anyone tell me how to check the attachment points, or is there a known failure associated with the front seat attachments?
Thanks,
Ian
Old Oct 21, 2008 | 03:14 PM
r52pimp's Avatar
r52pimp
Sorry I can't help you. Maybe get one of them "if the seat is arocking...." bumper stickers?
Old Oct 21, 2008 | 04:25 PM
Eurothrasher's Avatar
Eurothrasher
Thanks,
Ian
Call your MINI dealer's service dept, see if there are any TSB's for this problem.....Either way, I am sure they may have a fix kit if this is a common issue. Somtimes it is as simple as swapping out one kind of washer for another type......
Old Oct 21, 2008 | 05:32 PM
idickers's Avatar
idickers
seat bolts
The problem is that the bolts that hold the seat to the slider have backed out. Each side has a foot that sits in the track of the slider, and each foot is held on by two pan-head torx bolts. That means I should have 4 bolts on the two front slider feet, I currently have none . It looks like I'll have to remove the side panel of the seat bottom to be able to install the bolts, has anyone "dissected" a front seat? It looks like the seat rake adjuster has to come off, but other than that I'm in the dark.
Ian
minicoclub
Aug 25, 2015 09:07 AM
Powershift
Aug 16, 2015 05:14 PM
Miniburb
Aug 15, 2015 07:20 PM
FLYM1N1
Aug 15, 2015 11:20 AM
