Changed oil - small amount of oil below car in morning
Old Oct 15, 2008 | 05:23 AM
k_h_d's Avatar
k_h_d
I changed my oil last night. Used a Napa Gold filter. It went smoothly and the canister was easy to put back on. I oiled the o-ring so it would slide smoothly. Started the car, checked for leaks around the housing and it was fine. Drove it a bit. Checked for more leaks and it was fine.
This morning there was a small amount of oil from under the canister. I checked it. Backed it off just a little and re-tightened it. Oil level is fine so I drove to work.
Any ideas how its leaking out of the canister? It threaded on just fine. Can I back the canister back out and double check the o-ring? Or will oil leak everywhere?
Thanks,
k
Old Oct 15, 2008 | 05:30 AM
newbs49's Avatar
newbs49
The canister is full of oil.
Old Oct 15, 2008 | 08:33 AM
jimz68's Avatar
jimz68
When you loosened the canister (the first time) did you let it drain before removing it from the car ?
Jim
Old Oct 15, 2008 | 09:14 AM
k_h_d's Avatar
k_h_d
Yes, I let the canister sit and drain. I did not spill any oil from the canister during the oil change. The oil on the ground the next monring was clean oil.
Can I remove the canister without draining the oil to check the o-ring? If that does not solve it I will get a mini oil filter and use that instead of the Napa. Lots of people said the Napa works great but it was a little different looking.
K
Old Oct 15, 2008 | 03:51 PM
k_h_d's Avatar
k_h_d
I bought an Mini OEM filter and put it on. The O-ring from that filter is much more substantial and thicker than the o-ring from the Napa filter. That should have solved my issue.
Old Oct 15, 2008 | 04:27 PM
norm03s's Avatar
norm03s
My friend had the same problem with an after market oil filter, the O ring was undersized. Replaced with OEM MINI filter problem solved.
Old Oct 18, 2008 | 03:57 PM
TRuTH's Avatar
TRuTH
I had the same problem with an STP filter, and also noticed the o-ring was much smaller thickness wise and as soon as I put in an OEM filter no more leaking.
TREX
Nov 2, 2019 07:31 PM
Colt45Magnus
Jul 14, 2019 06:18 PM
ludedude
Aug 10, 2015 07:16 PM
eliseo1981
Aug 6, 2015 05:00 AM
