Suspension Early 02 to later front sunspension
Old Oct 13, 2008 | 03:52 PM
xnotfunkylex's Avatar
xnotfunkylex
Can anyone tell me what the differences are between the early 02 MC front suspension parts Vs. the later 02-04 parts. I really want to know why the parts aren't compatible and if it's possible to update it and how hard that would be.
I want coilovers, but it's hard to find a cheaper set that will fit the early models. Thanks in advance
Kyle
Old Oct 13, 2008 | 04:04 PM
AutoXCooper.com's Avatar
AutoXCooper.com
The differences in the strut rod size that fits into the bearing on the top plate. The very early MINI's had a smaller one that fit into a top hat without a bearing, but a bushings setup. You can change over to any after market Coilover system that comes with new top hats or camber plates. You can also buy new camber plates, IE Fixed are good, and use any shock, but OEM, you want with say TSW springs too.
Old Oct 13, 2008 | 04:35 PM
xnotfunkylex
Cool, thanks. I was thinking of going with V-Maxx coilovers and now I think I can.
Old Oct 13, 2008 | 05:58 PM
AutoXCooper.com
The easiest way to be sure is take a light and shine it down the hole at the top of the strut tower, under the hood, and if you see bearings you are good to go. If you are thinking about V-Maxx you might also think about Megan's.
Old Dec 17, 2008 | 06:44 AM
Stratmosphere's Avatar
Stratmosphere
V-Maxx Coils are on a one day sale at $454.
https://www.northamericanmotoring.co...2-17-08-a.html
Old Dec 17, 2008 | 08:36 AM
k-huevo's Avatar
k-huevo
The early model also had a different stablizer link and attachment tab on the strut body; to upgrade, later model drop links will be required, along with guide support/top mount, bearing cap, dust protection washer, strut washer, upper spring seat, and upper spring seat pad.
Old Dec 17, 2008 | 02:21 PM
xnotfunkylex
Just bought my V-Maxx's. Can't wait.
Old Dec 23, 2008 | 01:20 AM
xnotfunkylex
So I just bought a set of V-Maxx coilovers and now I want to know if I will need anything special to fit these to my 02-02 build date MC?
Old Dec 23, 2008 | 09:31 AM
MUShadd's Avatar
MUShadd
CRAP, missed a great sale :( let me know how they turn out for you!
Old Dec 23, 2008 | 10:40 AM
batrugger's Avatar
batrugger
You should check back with Stratmosphere. I heard they were still selling at that price.
Old Dec 23, 2008 | 03:15 PM
nickbmw's Avatar
nickbmw
This is one of the differences. The second difference, are the front sway bar end links. On early models, the sway bar end link attaches on the spring perch (if i use the correct work), unlike the later models, that the sway bar end link attaches on the body of the shock. So, changing the top mounts is not enough, he has to get end links, all the rest are the same.
Old Dec 23, 2008 | 07:07 PM
xnotfunkylex
Thanks nick. The V-Maxx's come with new end links because they are needed to lower the car over 40 mm. SO I think I will be ok there. And I think I will just get some camber plates to fix the top mounts.
Old Dec 23, 2008 | 07:08 PM
xnotfunkylex
They still have 20% off of them. Not the 30% I got but still brings them down to around $530 I believe. I say you go for it.
Old Dec 23, 2008 | 07:41 PM
MUShadd's Avatar
MUShadd
when do you plan on installing yours? i'd like to hear another opinion, especially concerning ride quality. I wont be able to have the funds until after xmas..around the first part of January. yay tuition reimbursement.
Old Dec 23, 2008 | 10:08 PM
xnotfunkylex
They are supposed to get here on the 29th, so depending on what else I need to update my early build parts it should be installed by the first week of 09 i would think. I'll definitely let you know how they feel.
Mini7
Feb 2, 2016 07:52 PM
ltjpunk7
Sep 6, 2015 07:32 AM
FLYM1N1
Aug 15, 2015 11:20 AM
Minibeagle
Aug 13, 2015 10:00 AM
