R50/53 Brake Pad Change
Old Oct 10, 2008 | 03:07 PM
hockeyman's Avatar
hockeyman
Brake Pad Change
Is there a way to release the pressure in the caliper without opening the brake fluid system? I would imagine I could turn the car on which would allow the caliper to relax, then I could use a firm, flat, wide object to depress the piston allowing me to install new pads. No?
Please advise .
Old Oct 10, 2008 | 03:13 PM
orbitup's Avatar
orbitup
I use a C-clamp. Put one side on the back of the caliper and the other on an old pad against the piston and slowly tighten it up. If you don't have one, they are pretty cheap at any hardware store.
Old Oct 10, 2008 | 03:16 PM
hockeyman's Avatar
hockeyman
OK so I was afraid to admit that's my method too, but the piston does not seem to want to budge? Am I just whussin on the crank? I would hate to break something. Any thoughts on starting the car without there being any pads installed over a rotor? I have this fear of the piston rocketing out of the sleeve or something crazy.
Old Oct 10, 2008 | 03:19 PM
orbitup's Avatar
orbitup
Have you tried taking the cap off of the reservoir? It'll probably spill some if you don't siphon some out.
Old Oct 10, 2008 | 03:20 PM
Capt_bj's Avatar
Capt_bj
OK - short answer here
have you read the DIY guide here from Octane Guy?
Break
The Haynes book says open the bleeder valve to allow easy pressing back of the caliber w/out introducing bad fluid back into the system. Their logic is solid but I'm of the opinion that not opening the system is as good .... and you can easily press the front pistons back in with a C clamp as noted above to give room for replacement. Did you loosen the resiv' cap?
ON THE REARS on the other hand .... dont forget that the e-brake system requires you turn the piston as you press it back (many posts). The Harbor Freight kit ($20) is a popular solution.....
(have you topped off fluid along the way? Monitor your brake fluid level as you press pistons back in.....)
Old Oct 10, 2008 | 03:24 PM
hockeyman's Avatar
hockeyman
OK so now I should mention that "our plan" worked perfectly for the fronts. I am having trouble with the rear only. The piston just seems so tight....the Ebrake is off. (I think that's mechanical anyway, right? Meaning Cable not Hydrolic)
If i open the reservoir and remove a bit you think that may do it?
Old Oct 10, 2008 | 03:28 PM
hockeyman's Avatar
hockeyman
Break
Thanks for the info...I did not read the DIY
I will release the res cap to see if that helps. When I am depressing the rear piston, which way does it turn to accommodate for e-brake? Going to find Octane's link....
Old Oct 10, 2008 | 03:29 PM
Capt_bj's Avatar
Capt_bj
DANGER WILL ROBINSON....DANGER
as I recall the turn is CW
Old Oct 10, 2008 | 03:31 PM
hockeyman's Avatar
hockeyman
Yeah, but i don't have HF near by.......any chance you can elaborate a lil?
Old Oct 10, 2008 | 03:39 PM
Capt_bj's Avatar
Capt_bj
You need to turn the rears as you press back
I belive the direction is clockwize but truthfully since the tool controls this....
But the rears MUST be turned as they are pressed back.....r they won't go.
Old Oct 10, 2008 | 03:42 PM
hockeyman's Avatar
hockeyman
I belive the direstion is clockwize but truthfully since the tool controls this....
OK cool, so I found the link OctaneGuy has and while I don't have the HF kit like that, I do have a very similar tool. Instead of the piston sized plates, I have a flat piece or 1/8 steel. It would have to be clockwise in order to be done at the same time as depressing the piston I think. Gonna give it a shot.
Old Oct 10, 2008 | 03:44 PM
Capt_bj's Avatar
Capt_bj
I think ur good ...
the HF tool has the same twist of every similar tool I've seen
Old Oct 10, 2008 | 03:45 PM
hockeyman's Avatar
hockeyman
I think ur good ...
Good Luck.....we're all counting on you. - Airplane the Movie
Old Oct 10, 2008 | 07:37 PM
hockeyman's Avatar
hockeyman
Mission complete! Ready to motor! Thanks for the tips as always!
Old Oct 10, 2008 | 08:11 PM
orbitup's Avatar
orbitup
Good job, say out of the ditches!
W0TM8
Dec 19, 2019 07:50 AM
bjcarter2
Aug 31, 2015 04:03 PM
Beau B
12
Aug 24, 2015 01:50 PM
