Chicago MINI Motoring Club The Chicago MINI Motoring Club Forum. Visit our club site at www.chicagominiclub.com
Oil Changes
Old Oct 9, 2008 | 07:43 PM
zagadka's Avatar
zagadka
Oil Changes
...or "earl" as I like to call it.
Do you change your own? Have someone else do it?
Where do you have it done? How much?
What brand of "earl" do you use?
I used to change the oil in my old car, but it was a little more accessible even though I had to drive my car up on a 2x4 to slide underneath it...never attempted to learn how to change my MINI's oil. Not sure why...laziness most likely.
Old Oct 9, 2008 | 08:23 PM
ernesto's Avatar
ernesto
Coordinator :: Chicago MINI Motoring Club
Been doing my own oil in both MINIs since they are old now..
not too bad to do it yourself if you are careful
Old Oct 9, 2008 | 08:25 PM
AutoXCooper.com's Avatar
AutoXCooper.com
Here's the How To, https://www.northamericanmotoring.co...ead.php?t=4928
or check with my local partner shop found at http://www.autoxcooper.com/service_providers.html for getting done outside of a dealer.
Be careful if you go somewhere that doesn't do them often, they may not change the oil filter or may use a cheap aftermarket that will leak.
Old Oct 9, 2008 | 09:14 PM
Schwinn's Avatar
Schwinn
I don't change my oil anymore. I actually bring my filter and oil with me and have someone else do it. Usually a shop near my house. Costs a bit under $20 when I supply and I don't have to get dirty.
Oh and I use Mobil since you asked.
lovethecorners's Avatar
lovethecorners
With my 2003 MCS, I changed it myself. Sometimes I would try to find the right Castrol that matched what MINI uses. Sometimes if I was close to my dealership or wanted to speak to my MA, I'd shell out $7/quart for the 5 quarts of MINI-branded lube and just sleep better knowing I did the job myself, put in the right stuff and supported my dealership even if I paid more than I should. The instructional link from AutoXCooper.com is right on.
I now have a 2006 MCS under scheduled maintenance so I'm going to let them do it for convenience and cost, except when I decide that it needs to be done prior to the computer's oil change calculation (e.g. if the color/opacity starts to go south or after a few track days).
I've only ever owned MINIs so maybe the "excitement" of performing your own oil change just hasn't worn off yet, but there is something satisfying about doing it yourself.
Old Oct 10, 2008 | 04:21 AM
kenchan's Avatar
kenchan
i buy Mobil1 at walmart in those 5qt jugs ($22?) and filter either online
or pick it up at patrick.
the filter canister can be a pita to screw back on at times. push and twist,
push and twist... until it threads itself in.
Old Oct 10, 2008 | 06:46 AM
zagadka's Avatar
zagadka
i was actually thinking about heading over to the rover shop today! i also need a belt replacement, which i happen to have in my boot!
Old Oct 10, 2008 | 04:52 PM
PiercedMini's Avatar
PiercedMini
If your closer to the coast Import Service in Glenview does a great job with the mini's. Oil changes and all other types of install or service they take care and are Import specialists, especially german imports.
Old Oct 10, 2008 | 07:47 PM
kenchan's Avatar
kenchan
murray's is having a sale of mobil1... case of 6qts for $29.99. not the
cheapest but i got a case today.
Old Oct 10, 2008 | 09:35 PM
minimarks's Avatar
minimarks
Change it myself, Royal Purple and a Mini filter.
CardinalsRule
Jun 11, 2016 04:34 PM
molala
Oct 2, 2015 01:53 PM
Sep 4, 2015 09:10 AM
Sep 3, 2015 03:01 PM
Sep 2, 2015 09:05 AM
