Heater not blowing heat
Old Oct 6, 2008 | 12:52 PM
4GAZM's Avatar
4GAZM
hello its been a problem for a while now but now its getting agravating since its starting to get cold, my heater will not blow hot air its just like getting in and starting the car up and having it blow whatever the ambient air is around you, the AC doesnt work anymore but thats another story.
now i know to check the coolant level and all is fine their, sometimes it blows hot then most of the time nothing, it also has a luke warm heat coming out of the driver side from time to time then cold air coming from the passinger side at the same time could the door inside the hvac be stuck preventing the heat from coming throu or could the automatic air modual on my center stack be fouling up? any ideas would be soooooo apreciated so i can look into this and hopefully figure it out, maybe theirs something i missed!!!!
thanks guys
christian
Old Oct 6, 2008 | 01:02 PM
BlimeyCabrio's Avatar
BlimeyCabrio
There are one or two servos in the dash that control the flow of air through the AC vs. the heat exchanger. There have been reports here of the sticking sometimes, and failing sometimes.
http://www.realoem.com/bmw/showparts...48&hg=64&fg=45
Old Oct 19, 2008 | 07:34 AM
carla99's Avatar
carla99
anyone else having this issue? Similar issue started with my 2 nights ago. I have an '07 MCSa. I am driving along the other night and go to put my heater on and its working fine then I gradually begin to feel the temperature cooling....eventually to almost feeling like the a/c is on...then it began to get hot again. This hot/cold temperature flux happened for my entire 20 minute drive....and again all day yesterday. Any suggestions anyone? I have the manual temperature control, not the automatic.
Old Oct 20, 2008 | 06:15 AM
Ozbone's Avatar
Ozbone
I'm having the same issue with my '05 MCS with auto air. Regardless of temp or distrib. it blows only cool or air-temp. air.
UPDATE Just spoke with dealer (MINI of Annapolis) and the first opening for them to simply look at the problem is 10 DAYS OFF! Guess I'd better start dressing for the cold - or hope the weather warms up !
Old Jan 15, 2009 | 06:52 AM
skillet's Avatar
skillet
Any updates as to what the problem is? Mine just started doing this, and it's currently -3 outside...not cool
Old Jan 15, 2009 | 11:42 AM
frenchie's Avatar
frenchie
Do a search for the A/C heater diagnostics and report the results.
Old Jan 15, 2009 | 12:07 PM
skillet's Avatar
skillet
Thank you. For future reference here's the link to the page that Frenchie is referring too.
https://www.northamericanmotoring.co...e-problem.html
Post #15 & #17
I'll post up the codes or whatever it reads here shortly...
Old Jan 15, 2009 | 12:20 PM
skillet's Avatar
skillet
Ran the diagnostics and it pulled a 00 fault...according to that list, there is no 00 Any other ideas?
Old Jan 15, 2009 | 02:18 PM
Kelly Girl's Avatar
Kelly Girl
have your thermostat checked out.
my mini did this a while ago and my thermostat wasn't working properly
Old Jan 15, 2009 | 02:23 PM
skillet's Avatar
skillet
Cool. I'll have to do that. Any way to check it without pulling it out? I mean my car is getting up to operating temperatures and staying there in the sub zero weather...Thanks Kelly
Old Jan 15, 2009 | 03:35 PM
Kelly Girl's Avatar
Kelly Girl
I don't know how to check it, i'm not that mechanically inclined.
But it's worth haveing the dealer or another gear head to take a gander at it
Old Jan 23, 2009 | 07:52 AM
skillet's Avatar
skillet
Kelly, thanks for the heads up. I do believe you're right. Although my aftermarket temp guage has told me on the track I'm hitting 300-310*, my stock temp guage has always been dead in the middle. Well, yesterday, it hit 3/4 of the way up, and then slowly dropped back down to the middle... So I'm assuming my thermostat is sticking at some point, then opening? Egh, I'll just replace it anyways. Car has 115K on it
Old Jan 23, 2009 | 10:12 AM
Kelly Girl's Avatar
Kelly Girl
may i offer one caveat?
if you're driving and the temp gauge shoots to "H" you could potentially overheat.
this happened to me during my morning commute.
if you can't be towed, and need to get somewhere quickly
turn ON your heater
turn OFF your "AC" snowflake button
turn OFF the 'recycle air' on your settings
turn the fan selection to "HI"
open all vents
select all vents on your settings
this will draw the heat off your engine, and thus buy you some time to 'limp' to a safe place to be towed, or your dealer/mechanic
watch the needle tho, if it creeps to H, pull over and let it cool down for a couple minutes.. start again, watch that needle tho... you don't want to deal with more than just your faulty thermostat
good luck
Old Jan 23, 2009 | 11:38 AM
frenchie's Avatar
frenchie
It can be checked without removing; use a non contact laser pyrometer, point the beam at the thermostat housing, the temperature will jump when the thermostat opens. Note the temperature where the jump occurs and you will have your answer.
Old Jan 23, 2009 | 01:26 PM
skillet's Avatar
skillet
Ok, I'm not familiar with where the thermostat housing is? I've done a quick searched on here, but haven't found anything yet. Are there any pictures or a link that would help me out? I don't have a laser pyrometer, but should be able to get one fairly easy. As for the needle hitting 3/4 - H, it briefly hit that mark and then came down...It was all of a sudden though. It didn't slowly kreep up to the "H"...just an instant spike and then came back down
Old Jan 28, 2009 | 05:32 PM
purephase's Avatar
purephase
Same issue, getting checked tomorrow
My 06 Cooper is having the exact same problem. I'm hoping it's simply a faulty thermostat although I'm still not sure why a faulty thermostat would change the temperature of the air blowing out. That is, if it's hot and I want hot, hot air sould come out . Maybe I'm over thinking the issue but I'll let you all know what I hear tomorrow after a trip to the dealer.
Also got the quick spike to "H" during normal, city driving and an instant drop back down to to mid level. I've also noticed the fan is EXTREMELY loud and active for about 45 seconds after I park the car, a loud whine and then is subsides...
Old Jan 29, 2009 | 08:56 AM
skillet's Avatar
skillet
Yep, same symptoms as me. On a good note, I'll be scheduling an appt. with my uncle who works at a BMW dealership to get it replaced. I do plan on purchasing that other thermostat that has been mentioned. Not the stock one. It looks as if this alternative opens a bit more than the stock one. Let us know what you find out at the dealership!
Old Jan 30, 2009 | 11:01 AM
nervous's Avatar
nervous
I just had this same issue on my '06 MCS (no hot air / single temporary spike of the temp gauge) - dealer replaced my thermostat & 1st stage fan.
No more problems.
Nicefeet
Oct 1, 2015 05:08 PM
IFIXEM2
Sep 18, 2015 08:47 AM
Sep 16, 2015 02:10 PM
Sep 16, 2015 02:09 PM
KristaMcCoy
Sep 12, 2015 05:37 PM
