Cooper (non S) Modifications specific to the MINI Cooper (R50).
6-speed swap
Old Oct 4, 2008 | 10:40 PM
UKSUV's Avatar
UKSUV
6-speed swap
Well...I was too lazy to post on the TSW post so I decided to make my own...look if you want. There is a pic or two here...but a few more of the damage in the tranny to come. Thanks to all my Team Half *** homies. The fun part is putting this gaggle of crap back together (minus AC and all its parts)...
BEFORE::::::::
AFTER::::::::::
Old Oct 4, 2008 | 11:06 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Looks like someone lobbed in a grenade when you were not looking.
Good luck.
How hard could it be?!?!!?!?!?!?!
Old Oct 4, 2008 | 11:21 PM
07BPB's Avatar
07BPB
If I did that and my parents walked in on me at the same stage you are at, my head would surely be on the chopping board.
Old Oct 4, 2008 | 11:30 PM
Oxybluecoop's Avatar
Oxybluecoop
Looks like fun! Slap a turbo kit on there while your at it! $$
Old Oct 5, 2008 | 08:17 AM
UKSUV's Avatar
UKSUV
Good luck.
Well the Midlands didnt fare so well. As you can see its torn apart on the right of the photo. When we tore it apart it wasnt as bad as I thought. The top 2 gears in the top pan were chunked and the 32mm nut holding one of them on was stripped. Not the nut but the actual threads were missing...lol. Inside the case there were metal shards and gouges on the pickup arms but the gears look intact. So if anybody wants a set of decent gears...lol
Old Oct 5, 2008 | 08:28 AM
UKSUV's Avatar
UKSUV
So, upon removal of the engine and trans we found a few things that needed replacement.
1 - One of the shift cables because I used a screwdriver instead of a 12mm wrench to pry up on. The rubber boot was dry rotted and seperated from the housing.
2 - My top motor mount was completely dry rotted in a perfect circle around the bolt.
3 - While pulling the motor mount out I "overlooked" disconnecting the post O2 sensor and ripped the wires right out of it...but im not going to run an exhaust and I already have an CEL light...
4 - Eventhough the O2 sensor harness was tucked neatly away under the heatshield...at 4 points...the harness was burned almost completely through.
5 - Damn battery harness was chaffing again even after I fixed it (underside of battery box)
So, some things to look out for....mines an 03...
Old Oct 5, 2008 | 08:29 AM
UKSUV's Avatar
UKSUV
You think my wife is happy?!?!?! The garage was finally clean...
Old Oct 5, 2008 | 08:30 AM
UKSUV's Avatar
UKSUV
That avenue has already been addressed and is being worked on...lol
Old Oct 5, 2008 | 08:45 AM
istara's Avatar
istara
You're crazy
Old Oct 5, 2008 | 11:44 AM
kalbone's Avatar
kalbone
once yer finished...go get me an egg burrito... lol
Old Oct 5, 2008 | 03:56 PM
UKSUV's Avatar
UKSUV
Hey...guess who stole your air compressor...
Old Oct 5, 2008 | 03:57 PM
UKSUV's Avatar
UKSUV
Originally Posted by istara
You're crazy
You JUST realized that?!?!?
Old Oct 5, 2008 | 04:00 PM
UKSUV's Avatar
UKSUV
Ok....so anyways. Ran into my first hiccup....the bolts that hold the flywheel onto the block and the bolts holding the pressure plate/disc dont swap. They are different from a Cooper -> MCS. THAT wasnt in the TSW D.I.Y... So now the reconstruction is on hold until I can pick up the parts from the stealership cause LOWES RACING didnt have the bolts and neither did VATO ZONE....
Old Oct 5, 2008 | 04:57 PM
istara's Avatar
istara
Nope.. just felt this was an appropriate time to remind you You're going to have all that back in one piece in time for the west side meet this weekend, right?
Old Oct 5, 2008 | 06:48 PM
UKSUV's Avatar
UKSUV
As you might have noticed (or might not have)...I no longer associate myself with the DMC....... Only a few people...and I can name them on my left hand...
Old Oct 5, 2008 | 11:15 PM
MINIdriver85's Avatar
MINIdriver85
Well, keep us informed on how the swap goes, I'd like to do that too, and I guess if my wallet allows me to, I'll start searching the needed pieces next month...so when you finish, if you can please post a complete list of what you had to buy for the swap, including bolts that don't match and similar, that would be great.
Old Oct 6, 2008 | 07:51 AM
txwerks's Avatar
txwerks
Ah, excellent catch - my Exedy kit came with all new hardware and I didn't even think about that!
When you get the part #, I'll add it to the write-up.
Old Oct 6, 2008 | 03:28 PM
istara's Avatar
istara
Not a dmc event.. euros: http://azeuropeans.com/Forums/viewtopic/t=2074.html
Good luck with the rest of the swap!
Old Oct 9, 2008 | 10:56 AM
AZblackOUT's Avatar
AZblackOUT
and hes missing fingers on that side...
was the wife even happy to begin with?
I do have to give him props, i watch him bang that entire disassembly in under three hours almost all by himself. me shucking tools together and another pointing out where the bolts where...it was out and ready to laugh at in no time.
Old Oct 9, 2008 | 02:25 PM
checkmate2006's Avatar
checkmate2006
wooohooo I wish I was in PHX right now.
Old Oct 9, 2008 | 02:47 PM
glnr13's Avatar
glnr13
go justin go crazy ****
Old Oct 9, 2008 | 02:58 PM
txwerks's Avatar
txwerks
Did you find any broken teeth in the case of the Midlands like we did?
Man, that thing is SOOOOO fun to get apart, too. It was about Midnight when we decided (drunkly), "You know what would be fun to do? Tear apart that 2nd Midlands and see what was going on in there". And, we found teeth from the 1st gear and dog ring. Hrm, I'm thinking a transmission generally works better when there's all the teeth in place - ROFL.
All this crazy talk has me thinking a small Rotrex and 6 psi to get to 200 whp until I can build the stroker with ITB's...
Old Oct 9, 2008 | 05:43 PM
UKSUV's Avatar
UKSUV
We have pics somewhere around here.... When we took off the top cover...one of the shaft threads were completely stripped and the nut was floating around. The teeth on both gears were crunched. When we split the cases...there wasnt too much damage. The gold pickup forks were ground all the way down in chucks. But that was about it. A few gears had teeth chipped but still in a somewhat serviceable condition. But, you have to understand...I ran my tranny with no oil this time and over sped it to 8K.... Totally did it on purpose but no really...
Old Oct 21, 2008 | 05:37 PM
AZblackOUT's Avatar
AZblackOUT
is this done yet?
Old Oct 21, 2008 | 07:23 PM
UKSUV's Avatar
UKSUV
Originally Posted by AZblackOUT
is this done yet?
Hey buttface....you were supposed to call me for dinner. You owe me. And did Kal tell you hes gonna get the same rims as me but in gunmetal??? We are gonna be twins. Your gonna be the outcasted brother.
