R56 How to remove the airbag?
Old Sep 22, 2008 | 07:24 PM
jfman's Avatar
jfman
I ahve been trying to figure out how to remove the drive side airbag from the steering wheel and I have officialy run out of ideas. How does it come off?
Old Sep 22, 2008 | 07:48 PM
AliceCooperWA's Avatar
AliceCooperWA
I think it's just a couple of torx bolts and a wire harness...I think the torx bolts are behind the steering wheel. It's that simple just remember to disconnect the battery and leave it disconnected until it is all put back together. Connecting the battery without the airbag will cause the airbag light to stay on until it is reset by dealership.
Old Sep 22, 2008 | 07:51 PM
NSX JR's Avatar
NSX JR
No bolts.
First, disconnect the battery. Seriously.
Second, stick a small flat head screwdriver in the hole in the bottom of the steering wheel. Make sure the blade is facing front to back, not side to side. Push up and you will feel one side of the airbag release. Keep pushing up and the other side will release. That's it.
jfman's Avatar
jfman
I looked and I dont see any torx bolt or any covers. I removed the whole steering column from the car and nothing!
btw: I'm not too worried about an airbag light at this point
Old Sep 22, 2008 | 07:52 PM
jfman's Avatar
jfman
Originally Posted by NSX JR
No bolts.
Wow! I will try that! thank you!
Old Sep 22, 2008 | 10:36 PM
AliceCooperWA
Crap...sorry. Wrong gen thread. There are torx bolts on the first gen...
Old Sep 22, 2008 | 11:10 PM
rkw's Avatar
rkw
There's a writeup in this thread, including pics in a PDF attachment: https://www.northamericanmotoring.co...d.php?t=109892
Old Sep 23, 2008 | 12:51 PM
bsnyder100's Avatar
bsnyder100
But, WHY!
Old Sep 24, 2008 | 06:58 AM
Red Bull's Avatar
Red Bull
Can I ask why you want to remove it?
Old Sep 24, 2008 | 12:34 PM
jfman's Avatar
jfman
So I can sell it.
Old Sep 24, 2008 | 01:00 PM
Red Bull's Avatar
Red Bull
So I can sell it.
ooooo....did you fair OK thru the accident?
Old Oct 7, 2008 | 09:38 AM
mr_john73's Avatar
mr_john73
remove airbag passanger side
Any idea on how to remove the cover of the airbag on the passenger side in my cooper S. i bought a new carbon fiber board
thanks
Old Oct 7, 2008 | 12:16 PM
djam43's Avatar
djam43
Hopefully when you figure out how to remove it, you will replace it for the next buyer.
Old Oct 7, 2008 | 07:15 PM
Calmante's Avatar
Calmante
I hope the OP keeps us posted...
Old Oct 8, 2008 | 08:14 AM
BEFCo's Avatar
BEFCo
Clock Spring
Hi All,
I also need to replace my airbag on the steering wheel.
I found ADAMSALTAMINI's instuctions (Thanks!)
https://www.northamericanmotoring.co...ght=r56+airbag
But I believe the clock spring needs to be replaced also.
Does anybody know what needs to be replaced exactly?
Is it just the part under the wheel?
OR is it the whole assembly, turn signal switches and all?
Thanks!
I_drive_slow
Aug 27, 2015 08:41 AM
greekzilla
Aug 23, 2015 03:44 PM
DWooderson
Aug 10, 2015 09:12 AM
quality_sound
Aug 7, 2015 09:36 AM
