Suspension adjusting coilovers?
Old Sep 16, 2008 | 10:10 PM
Dead Ringer's Avatar
Dead Ringer
OK, just got my M7 coilovers on the car today, boy do they make a huge difference! Very nice and controlled feel...
Since these are my first set and I had a shop install them, I have no idea how to adjust them. The instruction manual doesn't help much, so I thought I would post my question here. I have 2 needs:
1. the drivers side rear sits about 2/8th's of an inch taller, so I need to drop it just a tad on that side. How do I drop that side?
2. the front end is kinda "bouncy", I want to firm it up a little, how do I do that?
thanks guys
Old Sep 17, 2008 | 07:44 AM
minipete07's Avatar
minipete07
I would def. let them settle in a few days or a week.... the "bouncy" feel in the front can be adjusted with the damping **** at the bottom of the coilover...it has 15 "clicks" all the way down(like you were loosing it) is softest...move your way up till you get rid of the bounce, i have mine in the front at 4 clicks up. .....As for the height adjustment, let it settle in then have the shop adjust it as you will need to have the cars alignment re adjusted...Hopefully the shop has experiance in adjustable suspension work. Good luck, once you work things out you'll love them even more!
Old Sep 17, 2008 | 10:18 AM
Dead Ringer
OK, I went out to the car this morning, jacked it up a little bit, saw this little **** (smaller than the rears, silver with dimples on it), I cant tell but does it need to be "loosened" to adjust it? The rears I set up with no problem, the front one doesn't want to turn...?
Old Sep 17, 2008 | 11:02 AM
minipete07's Avatar
minipete07
the fronts move....try up or down....it clicks, its just a little harder than the rears.
Keet
Suspension
Aug 30, 2016 03:46 PM
CooperSharp
Oct 12, 2015 09:21 AM
vetsvette
Oct 11, 2015 06:05 PM
Suspension Products
Oct 1, 2015 11:53 AM
Suspension Products
Oct 1, 2015 11:14 AM
