Alignment results
Old Sep 10, 2008 | 05:25 PM
donjulio's Avatar
donjulio
Alignment results
My steering angle has to be turned a few degrees to the right to go straight. So i went in for an alignment...
Midas, they used some computer gadget and here are the results:
left
camber -0.4
toe +0.14
right
camber -0.8
toe +0.12
After the alignment my steering wheel has to be turned about a few degrees to the left to go straight.
the technician said that was the case because of the camber that cannot be adjusted.
does anyone have any input on what the tech said? whether that is true or not
Old Sep 10, 2008 | 05:57 PM
Dr Obnxs's Avatar
Dr Obnxs
That's what you get from going to Midas!
The camber numbers aren't off spec. The spec is -0.5 +/- 0.5 deg each side. Yours is less out of whack than many. When you have to move the wheel, is it on crowned roads? Check tire pressures as well. If you don't have directional wheels, swap them side to side see if it changes. Anyway, I don't go to cheapy alignment places for just these issues. Also a "few degrees" isn't much, any better description than this?
Matt
Old Sep 10, 2008 | 06:01 PM
donjulio's Avatar
donjulio
well when i mean a few degrees, i mean like 8 degree so its pretty noticeable!
these are results from flat road, everything is okay, all same tire pressure
i made them do another alignment to correct this but the problem still exist and they blamed it on the camber.
MrBlah
SCCA Solo and ProSolo
Feb 1, 2020 07:43 PM
Keet
Suspension
Aug 30, 2016 03:46 PM
wildwestrider
11
Jan 29, 2016 05:06 PM
potterstein
Oct 1, 2015 07:10 AM
daviday
Sep 25, 2015 01:31 AM
