Suspension Do I have to disconnect the brake lines from the calipers to do a rotor swap?
Old Sep 10, 2008 | 09:27 AM
Mike S's Avatar
Mike S
Hi guys,
Just curious to know if it is necessary to disconnect the brake lines if I want to do a rotor swap?
Old Sep 10, 2008 | 09:32 AM
jasonsmf's Avatar
jasonsmf
nope
Old Sep 10, 2008 | 09:34 AM
MirthScout's Avatar
MirthScout
No. Its similar to OctaneGuy's howto on changing brake pads:
https://www.northamericanmotoring.co...ht=brake+howto
Just a couple more bolts to to remove the caliper (still connected to the brake lines) and suspend from something nearby with zip ties. Then one more bolt and a whack or two and you've got the rotor.
Old Sep 10, 2008 | 10:13 AM
JIMINNI's Avatar
JIMINNI
As long as there isn't to big a lip that formed along the edge, then it's alittle harder to get them out.
Old Sep 10, 2008 | 10:47 AM
Mike S's Avatar
Mike S
Great! My JCW rotors only have around 18,000 miles on them, there is hardly a lip.
Thanks again guys! You've been very helpful!
Old Sep 10, 2008 | 01:17 PM
Crashton's Avatar
Crashton
No, just don't let the calipers hang suspended by the brake lines. That is not good for them. I use a piece of coat-hanger & hang the calipers on them.
W0TM8
Dec 19, 2019 07:50 AM
ebowling
90
Aug 4, 2019 09:15 AM
Mini7
Feb 2, 2016 07:52 PM
minimofo
Dec 26, 2015 11:45 AM
StealthR53
Aug 8, 2015 10:59 AM
