R56 Recomend best Brake Pads for my Application
Old Sep 9, 2008 | 03:31 PM
OkieSnake's Avatar
OkieSnake
What Brake Pads would you recomend for me? My 08 MCS is my daily driver but I also plan to take it to the track about 7-9 times a year , (I have already taken it out 3 times so far).
Thanks in advance.
Old Sep 9, 2008 | 03:46 PM
LTLMCPE's Avatar
LTLMCPE
I've been using Porterfield's R4 or R4S in my 99 M coupe for years and this spring put a set in my 02 MCS for a track even with success. One is a combo pad and the other a full track pad. I used the high performance/autox pads and left them in the car. I think that's the R4S.
Jim
Old Sep 9, 2008 | 03:52 PM
AutoXCooper.com's Avatar
AutoXCooper.com
IF you are going to the track you need track pads. Think about running the Carbotech XP8's all around or XP10's in the front and XP8's in the rear.
There is no 1 pad for all things. The XP8 is about as 1 pad as you can get. There will be dust, about same as OEM, but it's a great pad for track events that you can run on a daily driver too. As you get faster and start going deeper you will want to upgrade the XP10's in front.
Old Sep 9, 2008 | 05:26 PM
OkieSnake's Avatar
OkieSnake
Do the Carbotech XP8's support the brake pad sensors for an 08 MCS? How every-day driver liveable are they?
Old Sep 9, 2008 | 05:30 PM
AutoXCooper.com
Yes they can be ordered with the Pad sensor slots and many find them very livable day to day.
squawSkiBum
Tires, Wheels, & Brakes
27
Nov 19, 2024 10:26 AM
Tires, Wheels & Brakes
Aug 26, 2015 10:28 AM
Aug 25, 2015 09:18 AM
