Questions about Rota RB wheels and Webspoke wheels
I am considering purchasing the 17 inch Rota RB wheels. I have read the Rota RB is a "hubcentric" wheel. Is that a problem? The Rota RB wheel is approximately 5 lbs. lighter per wheel then my current OEM wheel or the R98 - Webspoke. Will that make a noticeable difference in performance? Is the Rota RB a good wheel? Is it durable/tough? I would appreciate input from people on the fourm.
5 lbs per wheel is not that much difference for street use. It's fine. Just match it with good tires and you should be OK.
Hubcentric is good. Not a problem. MINI hub bore is 56.1mm so check the center hub bore on the Rota and it is quite a bit larger like 73mm then you will need centering rings, if it is 56.1mm then you don't need any rings.
Mini'mon
Aug 16, 2015 04:15 PM
ki7hy
Aug 12, 2015 07:07 PM
