Drivetrain Shrick Camshaft
Old Sep 6, 2003 | 04:05 PM
vdubdoug's Avatar
vdubdoug
Is anyone running a Shrick Camshaft in there Mini? Is it worth it?I did a search and found nothing
Old Sep 6, 2003 | 04:47 PM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
Doug,
Yep, I have been testing it as well as a couple others, and they don't do as much as hoped for. It is one of those mods that I would do after all other options have been extinguished.
Of the cams available, the Schrick is the best one, producing as much as 6 horsepower and a few foot pounds of torque. You have to make sure you have the correct cam - the Cooper and the S are both available, and I have had a customer get the wrong one from other vendors - be sure to ask which one they have.
With the head and cam, the most you can expect to gain is 10-12 horsepower.
Hope that helps! Feel free to contact me if you have any other questions.
Randy
720-841-1002
Old Sep 7, 2003 | 02:32 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
I was also interested in the shrick cam but if you consider the cost (roughly $500 for the cam, up to $1895 for the head, plus shipping/installation costs (4-5 hours?) for a conservative 10-12 horsepower gain??) it isn't the most cost effective mod. I guess I am dissappointed with the reality of it.
For cams
http://www.mini-madness.com/product....1=201&3=40
Schrick Camshafts have long been the industry standard. Dr. Schrick continues to produce the very best camshafts on the market through a continued commitment to improvement. All Schrick products go through extensive testing to ensure optimum power outout and reliability. Schrick camshafts are CNC machined to precise tolerances and are manufactured in Germany from expensive, extremely wear-resistant chilled cast billets. All Schrick products are backed with a one year unlimited milage warranty.
Camshaft specs: 252/260
or
http://www.turnermotorsport.com/html...ect_mini.shtml
Performance Head
http://www.mini-madness.com/product....1=201&3=64
Price not announced
http://new.minimania.com/web/Item/NME6001/InvDetail.cfm
Stage 1 Cylinder Head, street port for use with stock valve springs and stock cam. Designed specifically for street driven MINIs, our Stage 1 Cylinder head package maximizes torque and HP within the portion of the powerband you spend the majority of your time driving in. The result is a smooth and broad power delivery. With our Stage 1 Cylinder Head package, air flow is increased an incredible 20% without sacrificing port velocity. Intake-Exhaust interport relationship is also optimized for maximum power with efficiency. The combustion chamber is then reprofiled for improved combustion properties. Depending on parts used in conjunction with this Cylinder Head package, power gains are potentially 20-30HP. Please note that the shopping cart price will include a refundable core charge of US$1000. Once the Cylinder Head package has been shipped, you have 30 days to return your original components back to our factory to receive your refund. Your original components must be in good, re-usable condition to receive the full core charge amount.
Old Sep 7, 2003 | 08:38 AM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
minihune,
I agree. It just isn't that cost effective for the gains. The head and cam are for hardcore folks who must have it all, and it is the only way to get more horsepower after all of your other avenues have been traveled.
I do carry the Schrick for the Cooper and the S, as it is the only one with high enough quality (ie, it is a billet not a regrind) and it does not cause any idle problems.
I am also going to be carrying two different heads - one with larger valves and one that is just ported.
Like I said though, I don't recommend this for anyone except the die-hard, must have every last bit guys. There are other more cost effective ways to the power.
Randy
Old Sep 7, 2003 | 10:57 AM
TonyB's Avatar
TonyB
I'm sort of guessing that this combo, along with an aftermkt header will be the Madness Stage 3 package for which they are claiming 240-245hp...
Ok, time for my **** weight question While I realize the cam won't shave much, if any, how about the head?
_________________
2003 IB MCS
Steffen.Johnson
71
Jan 26, 2021 09:11 AM
yukinoinu
11
Sep 25, 2015 09:48 AM
sirfrank
Sep 11, 2015 01:36 PM
Sep 11, 2015 11:09 AM
