help me spend on 17" track/daily wheels
i am going to get a new set of 17" wheels, and relegate my sidewalk's "night spoke" wheels for winter use. the night spoke reportedly weighs about 20 lbs. i have bc coils, which neccessitated a 5 mm spacer to avoid rubbing with the shock bodies. brakes are probably going to stay with stock calipers, and continue to switch carbotech bobcats for daily driving and xp8's for the track. lugs are 14mm. i'm running dunlop direzza star spec 215/45-17's. so im thinking: oz ultraleggera in black or graphite, enkei rpf1 in black, and motegi tracklites (forged) in black. the cost between these doesn't matter to me....so what would you choose and why? any alternatives in the 15 lb. range? thanks!
Other options in lightweight wheels are the Enkei RS+M, although they are a shade over 15 lbs., and if you can wait a bit, the new OZ Alleggerita HLT sounds very promising, estimated at 13.8 lbs in a nine spoke pattern.
Those you mentioned are pretty good choices, the RPF1's in particular look great in 17", whereas the 16" version looks a little small due to the lip design.
At 15 lbs and at less than $200 each I bought these Kosei K1 from Tire Rack.
http://www.tirerack.com/wheels/Wheel...All&sort=Brand
+1 for SSR's.Strong ,light,rarely seen out on the roads.(Not sure what the changes are to product line after they changed ownership?)I love 'mine.I was leaning to the Kosei's as a 2nd choice when I was in the market for wheels a year ago(1/2 The $)
SosoMINI
Nov 22, 2015 03:17 PM
Colt45Magnus
Sep 7, 2015 10:47 PM
L3Mix
Aug 26, 2015 07:00 PM
nismo4life
Aug 5, 2015 08:31 AM
