Will 15" 4x100 VW Jetta Spare Tire Work
Old Aug 25, 2008 | 08:31 PM
rasputinj's Avatar
rasputinj
I found a 15" 4x100 97 VW Spare Tire will that work on the Mini Cooper? Is there anything else I need to look for like?
Old Aug 25, 2008 | 08:46 PM
ScottRiqui's Avatar
ScottRiqui
What kind of VW is the spare from? I don't know if all VWs are front-wheel drive, and if the spare is meant for a RWD car, there may be offset issues.
Also, what year is your MINI? The later cars (post-July 2006) come with 14mm wheel bolts that might not fit through the bolt holes on the VW wheel.
Old Aug 25, 2008 | 09:06 PM
AutoXCooper.com's Avatar
AutoXCooper.com
test it to make sure it fits and the lug bolts seat right too.
Old Aug 25, 2008 | 09:08 PM
searocko's Avatar
searocko
The Jetta, like all watercooled VWs, have 57.1mm centerbores and the OEM wheels use ball seat lugs. MINI has a 56.1mm centerbore and use conical or tapered lugs. The VW spare isn't fully hubcentric but the difference is so slight, it may not be an issue for temporary use.
Also, 4-bolt VWs use 12mm diameter lugs.
Old Aug 25, 2008 | 09:17 PM
ScottRiqui's Avatar
ScottRiqui
I'd be less concerned with the difference in hub size than I would the fact that the VW wheel is designed for ball-seat lug bolts rather than tapered bolts.
And it's not like you can pick up a separate set of bolts to put on when you need to use the spare, because I don't think you can find 14mm X 1.25mm lug bolts with a ball-head on them.
Old Aug 25, 2008 | 10:07 PM
rasputinj's Avatar
rasputinj
Thanks for the info, I will keep an eye out for Miata, Cobalt, Taurus spare tire for 2009 Clubman S.
Old Aug 25, 2008 | 10:10 PM
rasputinj's Avatar
rasputinj
How about a 2001-2005 Civic spare 15" 4x100? I remember reading somewhere that 15" Civic spare would work.
From a little bit of Googling it looks like the Civic has a Centerbore of 56.1mm and 14mm, does this sound right?
Old Aug 25, 2008 | 10:13 PM
ScottRiqui's Avatar
ScottRiqui
I think you can scratch Miata rims off of your list as well. They have a centerbore diameter of 54.1 mm and therefore won't fit over the MINI's 56.1 mm hubs.
Old Aug 25, 2008 | 10:41 PM
rasputinj's Avatar
rasputinj
I will have to do further research on the Civic 2001-2005 15" wheels to verify the 56.1mm centerbore and 14mm lug bolts.
Old Aug 26, 2008 | 12:28 AM
rasputinj's Avatar
rasputinj
Looks like the Civic 15" spare will be the right Centerbore but takes 12mm lug bolts. Can I just drill them out to 14mm?
Old Aug 26, 2008 | 05:42 AM
Rally@StanceDesign's Avatar
Rally@StanceDesign
No steel wheel's lug holes are pressed. Redrilling them is not a good idea.
Old Aug 26, 2008 | 06:33 AM
ScottRiqui's Avatar
ScottRiqui
You might not have to re-drill the Civic wheels. Even though they use 12mm bolts, the bolt holes themselves may be large enough to work with 14mm bolts. That's how it is with MINI wheels - even though the first-gen cars used 12mm bolts, all of the factory wheels from the first-gen cars will work with the newer 14mm bolts.
One more potential wrinkle - don't you have a Clubman 'S' (or at least, have one on order)? I don't think there are any 15" wheels that will fit over the R56 'S' brakes without clearance issues.
Old Aug 26, 2008 | 07:34 AM
Alex@tirerack's Avatar
Alex@tirerack
I have a few, just call me
Alex
Old Aug 26, 2008 | 08:42 AM
ScottRiqui's Avatar
ScottRiqui
Thanks for chiming in, Alex - Now that I think about it, I remember you saying in another thread that you had some 15" rims that would work with the R56/R55 'S' brakes. I was thinking about OEM rims, since that's what the OP seemed to be looking for. I didn't even think about aftermarket.
kazyn
Oct 25, 2019 02:34 PM
FLYM1N1
Oct 13, 2015 04:33 PM
blackie
Aug 23, 2015 08:44 PM
Mrdi
Aug 7, 2015 01:06 PM
