Changing to winter tires
Old Aug 24, 2008 | 07:47 AM
MiniMama2's Avatar
MiniMama2
I have several questions about switching to winter tires on my new 2008 MCS.
I am currently using OEM 16" wheels with OEM all season tires run flats. I like the convenience of run flats for the type of driving I do. (Commute to center city through very bad neighborhoods = need to keep moving!).
Should I change to a 17" tire for winter?
Have used Alpins for winter tires on my BMW and really liked them. Are they suitable for the MINI or is there a better tire?
Is there a runflat winter tire that I can buy that would work with the MCS?
Will a 17" rim change affect the speedometer readings or any other mechanical processes?
I have always relied on my dear hubby for this, but he isn't sure about the MINI issues. Thanks in advance.
Old Aug 24, 2008 | 08:17 AM
AutoCoarsen's Avatar
AutoCoarsen
You can use a 17" winter wheel/tire, but for other than aesthetic reasons, it's not necessary. If you buy the proper sized 17" tires for a 17" wheel it will not affect the speedo. 16" will be the cheaper option
Check out tirerack.com. There are a few options for runflat winter tires. For a 16" wheel, the recommended tire size is 195/55-16. With that size you can get the Dunlop SP Winter Sport 3D or Goodyear Eagle Ultra Grip GW3, both in runflat construction.
The Dunlop is a highly regarded performance winter tire.
Old Aug 25, 2008 | 11:53 AM
Alex@tirerack's Avatar
Alex@tirerack
runflat winters
16's
17's
Alex
FLYM1N1
Oct 13, 2015 04:33 PM
sprp85
Aug 22, 2015 06:16 AM
col127
Aug 21, 2015 02:11 PM
FLYM1N1
Aug 16, 2015 01:17 PM
Dashdog
Aug 10, 2015 06:17 AM
