Drivetrain Intake Port Matching
Old Aug 21, 2008 | 06:50 PM
mini_racer's Avatar
mini_racer
So, in the process of a head swap I noticed that the intake runners are significantly smaller that the gasket to the head. While the head very closely matches the intake gasket dimensions.
Anyone out there with dyno numbers on porting the intake manifold? Any theoretical value to porting the intake? Or is it better for the head ports to be larger than the intake?
Sorry about the poor pic I took with my phone.
Old Aug 21, 2008 | 08:10 PM
kapps's Avatar
kapps
Better to have the head ports larger than the manifold but best flow will always be with a smooth transition between the two. It could simply be production tolerances in the design to ensure there will never be a step inward from the manifold to head.
I'm not sure if anyone's done any testing to see what the gains may be.
Old Aug 22, 2008 | 04:44 AM
Bahamabart's Avatar
Bahamabart
This is a question for Jan at RMW, give him a call.
Old Aug 22, 2008 | 05:34 AM
mini_racer's Avatar
mini_racer
I was hoping Jan would chime-in and provide his opinion, as well as anyone else with some experience and hopefully data on this topic.
http://www.circletrack.com/techartic...ing/index.html
http://www.sa-motorsports.com/diyport.aspx
http://www.automedia.com/Port_Matchi...es20040801pm/1
http://www.tmossporting.com/tabid/3104/Default.aspx
Obviously some believe this is very important, but does this have actual value for ths engine/configuration?
Old Aug 22, 2008 | 07:48 AM
spdfreak's Avatar
spdfreak
When I did my RMW head I had noticed that the intake manifold was much smaller than the ports on the head. I asked Jan if I should port match it and he really didn't think it would make much difference. I think (Just an opinion) that since our cars are S/C that transistion isn't as important as on an N/A car.
Old Aug 22, 2008 | 08:06 AM
mini_racer's Avatar
mini_racer
That is what I meant by 'engine/configuration'. I have a similar suspicion, but I don't 'know', since I do not have any data (dyno numbers).
Anyone out there with some hard data?
Old Aug 22, 2008 | 08:26 AM
astrochex's Avatar
astrochex
ENDYN ports MINI intake manifolds. Give them a call.
http://theoldone.com/components/cyli...ead_modifi.htm
Old Aug 22, 2008 | 09:01 AM
mini_racer's Avatar
mini_racer
Thanks Astro,
Just gave a call, and an email with a link to this thread. Maybe we can get post from them for the benefit of us all.
Old Aug 22, 2008 | 10:27 AM
k-huevo's Avatar
k-huevo
Anti-reversion steps are beneficial for both NA and FI applications, although less critical for FI intake paths where higher boost pressures can forgive small sins. I don’t have hard data, but from a discussion I had with Corky Bell over transition issues, he considers perfecting intake path transitions low on the priority list; his recommendation “turn up the boost”, of course our Roots style SC has limitations.
Personally, I can’t let go of the obsession and feel every little bit helps. Take a look at the intercooler output duct, IM interface, and gasket, there is probably a mismatch at that location which can be improved upon also. The entrance to the IC output duct has a square shoulder that could be smoothed over or knife edged to provide some laminar flow benefit. Get a feel of the ICOD’s interior to make sure there are no giant casting flash blobs while you’re at it.
My stock head and intake manifold suffered from core shift in opposite directions; yours doesn’t appear to have that characteristic from what you’ve said. On my Endyn modified intake manifold and head, the IM gasket also required reshaping to match injector troughs and port profile. In the case of part manufacturing irregularities, or when you don’t want to leave any stone unturned in the pursuit of gains, or it is dictated by the head porter’s design, port matching the IM has more value.
Old Aug 22, 2008 | 02:26 PM
Longboard Mini's Avatar
Longboard Mini
Bingo, it's all little things combined with the big that really make a system work.
I have an RMW port matched intake on my car .
Longboard
Old Aug 22, 2008 | 02:56 PM
Tüls's Avatar
Tüls
Turbius Maximus
Every little bit helps, but the most important thing to understand is going from the exhaust side to the header is more critical because you dont wanna suffocate, where from intake side going from smaller intake runners to bigger ported head is a transition that is easier if you will. Opening up is ok where squeezing down is an issue. There are many other factors but this is something that may ease minds. Matching is ultimate, so if it can be done. Do it.
Old Aug 22, 2008 | 03:58 PM
mini_racer's Avatar
mini_racer
Thanks for the input guys. I am just about done with the intake and SC horn porting. It is really pretty easy as Aluminum cuts like butta.
Obviously I am not sure how much performance this will deliver, but it damn sure can't hurt.
Old Sep 7, 2008 | 07:23 AM
Thumper460's Avatar
Thumper460
It will help!! a smooth transition into the head is criticle!! ( and most missed on head changes) Yes the Positive air from boost is LESS criticle than than the n/a engine. However with that said, the air will tumble and bubble at the ledge of the inter face!! How much HP loss?? I havent got that deep into a dyno testing to try and prove the loss in numbers... but with it all exposed, and you adding the cost to add a better flowing head, seems like you would also look for power in at least a gasket match between the Intake- Head- and HEADER!! Yes?? The power is there, and that might be why some are faster than others with the same mods... atten to detail!! LOL
( EDIT..)
Just me..............................
Thumper
rtk90
Aug 29, 2019 09:08 AM
molala
Oct 2, 2015 01:53 PM
M7Speed
Sep 4, 2015 10:47 AM
M7Speed
Sep 3, 2015 07:48 AM
Sep 2, 2015 11:15 AM
