Suspension rear shock diagram
Old Aug 20, 2008 | 12:35 PM
terry glazar's Avatar
terry glazar
rear shock diagram
I have decided to reassemble my stock rear shocks (R53). Could someone please send me a diagram showing the components of the shock and order of assembly.
Old Aug 20, 2008 | 12:50 PM
PGT's Avatar
PGT
www.realoem.com - it's free
Old Aug 20, 2008 | 02:46 PM
terry glazar
spacer
Thank you for the link to RealOEM.com.
The problem I am having is that I also have a brass tube which fits exactly on the shock shaft but does not appear in the exploded view of the shock.
I just do not remember if it goes with the stock shock or not.
Anyone have any idea if it is part of the shock? My coilover instructions seem to refer to it as an "upper mount plate's spacing cylinder".
Terry
Old Aug 20, 2008 | 03:09 PM
quikmni's Avatar
quikmni
THe the stock rear shock. The tube is a spacer that goes in the top mount rubber bushings. There is a rubber bushing under the top shock mounting bracket (bracket with the two top mounting holes) and there is a smaller rubber bushing on the top side of the shock mounting bracket. The smaller top bushing fits around the protruding portion of the bottom rubber bushing. The tube/spacer fits inside the lower bushing and over the shock shaft.
Old Aug 20, 2008 | 05:13 PM
terry glazar
THANKS, That is the way I thought it went together.
I appreciate your quick response
Terry
STR3T
May 23, 2016 03:27 AM
Toolman
Jan 20, 2016 06:50 AM
JaysinStrife
Suspension
Sep 7, 2015 12:52 PM
Emnotek
Aug 13, 2015 05:47 PM
nomar116
Aug 10, 2015 11:24 PM
