Cooper (non S) Modifications specific to the MINI Cooper (R50).
B&M Shortshift installation!! HELP!!
Old Aug 13, 2008 | 07:30 AM
Rix's Avatar
Rix
Hey guys,
I bought the B&M shortshift kit,
and i want to install it myself, basicly thats not a problem, seem pretty easy.
My question is how i find the lower shift base.
When i raise my car i cant find it,
my question is, if i have to remove the protection plate there is mounted on to the car between the exhaust pipe and the car itself?
seems the instruction is lacking that part?.
It only tells me to remove the exhaust bolts to move the exhaust, to gain more space.
please help.. :D
Old Aug 14, 2008 | 04:19 PM
R50 Paul's Avatar
R50 Paul
Yup the exhaust sheild has to get dropped. Once the exhaust is outta the way, just find the little bolts that hold it in place. From there you'll see a white rectangular box. Unclip the bottom panel and there is what ya need. BTW the connector that is attached to the shifter is a royal PITA to take off (It was for me at least) so it may take some force to remove. Other than that, you MAY have to modify your exhaust shield if the new SS sits low. I have the Helix unit and had to modify the shield to make it work properly. BTW make sure the Cooper is in neutral before you take the linkage connector off the base of the shift lever....
Old Aug 15, 2008 | 07:20 AM
Rix's Avatar
Rix
great thanks alot
adrchn
Aug 13, 2019 02:11 AM
minimofo
Nov 5, 2015 08:40 AM
minimofo
Oct 25, 2015 05:53 PM
minimofo
Sep 9, 2015 10:29 AM
