which polish after touch up?
Old Aug 4, 2008 | 11:54 AM
deafbuzz's Avatar
deafbuzz
after did touch up on chip then use some langka blob. i noticed the dark silver (metallic) touch up is dull than regular glossy paint on my 2008 mcs.
i do have these:
pc 7424 from tools-plus
4 (yellow, orange, white and black) pads (6") comes with backing plate (5") from dp
4 (cut, swirl, finish, amigo) polish from dp
2 (epic & banna glossy) wax from dp
1 black wow from dp (why mention this cuz put it on trim before polish and wax.)
which one polish and pad (color?) that you recommend me to use the polish and pad on only touch up area to remove the dull and match with the glossy paint?
Old Aug 4, 2008 | 12:32 PM
BlimeyCabrio's Avatar
BlimeyCabrio
You could get it done with either:
Orange pad and swirl (definitely)
White Pad and swirl (probably)
White pad and Finish (maybe)
Definitely do NOT need the yellow pad, or black pad, or Cut, or Amigo for this specific task.
Personally, I'd probably use a bit of ScratchX on a hand applicator for 30 seconds and be done. Using the machine is overkill for this unless you want to polish the whole panel (or car) to make the whole thing perfect while you're at it, IMHO.
Old Aug 4, 2008 | 12:55 PM
andrewholmes's Avatar
andrewholmes
i would use a sand blaster!!
Old Aug 4, 2008 | 01:26 PM
MiniMaybee's Avatar
MiniMaybee
If you didn't use the clear coat after smoothing the paint blob then this is probably why it is dull. When I do chip repair I will use the clear depending on how big the chip is. If the chip is large (+1/8"), I will take the paint blob down to slightly below surface, then blob some clear on and take it down flush.
I use a white pad and swirl on a 4 setting to go over repairs. Then Amigo on a white pad and finally Epic on a black.
Old Aug 4, 2008 | 01:31 PM
BlimeyCabrio
Chuck speaks the truth. I was assuming you were using clearcoat properly... and had a little hazing due to the Langka treatment. So take either of our medicines based on whoever had the proper diagnosis.
PS. using the machine is still overkill for a chip repair.
Old Aug 4, 2008 | 04:13 PM
deafbuzz's Avatar
deafbuzz
oops, i did not touch up the last clearcoat yet. i guess i need to buy more microbrush again for clearcoat?
thanks for tips on polish, pad & scratchx.
scfiveo
Sep 27, 2019 02:27 PM
OutMotoring
Mar 3, 2017 06:29 AM
sempaipaul
Sep 14, 2015 09:16 PM
marc0011
Sep 10, 2015 10:04 PM
