18" OZ Ultraleggera Wheels
Old Aug 4, 2008 | 03:22 AM
mr_r56's Avatar
mr_r56
Hey,
I'm looking at getting a set of 18" OZ Ultraleggera wheels.
Just wondering what size I can fit on my R56 Cooper S ??
7x18" ?
7.5x18" ?
8x18" ?
I was hoping to put a set of 7.5x18" with 225/35 R18 tyres on the car, but I want to confirm if that will work before I go out and buy a set that won't fit.
What do you guys recommend ??
Thanks.
Old Aug 4, 2008 | 03:31 AM
works8's Avatar
works8
What's the offset you are looking at for the 18x7.5?
Old Aug 4, 2008 | 03:49 AM
mr_r56's Avatar
mr_r56
Not a clue for the 7.5x18"
7x18" would be a 42 offset.
I can run a 215/35 R18 tyre on that... right?
Old Aug 4, 2008 | 08:26 AM
Rausner's Avatar
Rausner
Yes you can run runt that. My OZ Record's are 18x7 ET38 with 215/35 R18 Toyo T1r's and fit perfectly. Where did you find the ultraleggeras?
Old Aug 4, 2008 | 03:08 PM
D Unit's Avatar
D Unit
Are you set on 18s? I put a set of 17s on and they drive just as good as my stock 16s did. In fact, I was still able to avg. a little over 37mpg on my last 3 full tanks and they look great. Good luck to you.
Old Aug 4, 2008 | 06:20 PM
works8's Avatar
works8
ET42 on the 7.5x18 should be spot on for inner clearance ie same as stock 7x17 ET48, so should have no issues there! 215/35R18 will fit on both 7 or 7.5, are you going non RFT?
Old Aug 5, 2008 | 02:16 AM
mr_r56's Avatar
mr_r56
I found the following places that sell O.Z Wheels in Australia:
http://www.talebtyres.com.au/index.asp
http://www.tyrepitstop.com.au/
http://www.magwheelcentre.com.au/
Otherwise - From the US:
http://www.tirerack.com/
Any other places??
Not sure about Run Flats yet. Need to look further into it, but thinking I might stick with them.
Old Aug 5, 2008 | 02:03 PM
jerjer's Avatar
jerjer
im thought they only make them 1 in size, 18x7 i thought, or whatever the size is on tirerack. i could be wrong tho, but i doubt they will make 4x100, the same diameter in 3 different widths.
Old Aug 5, 2008 | 11:44 PM
mr_r56's Avatar
mr_r56
http://www.ozracing.com/at-team/whee...ltraleggera/en
The website shows multiple width's for the same size.
But, I do see your point about the 4x100 as I dont see anything written about that. So you could be correct.
I've emailed TireRack for a quote on 7x18" & 7.5x18" and asked if they will fit.
I'll post back when I get a reply.
barnoun
Sep 17, 2018 05:04 PM
cawwwtun
May 3, 2016 08:03 AM
BRracing
Dec 22, 2015 09:25 AM
khumpert
Nov 30, 2015 11:48 AM
SosoMINI
Nov 22, 2015 03:17 PM
