Canned Air Recommendations
Old Aug 29, 2003 | 08:43 PM
MGear's Avatar
MGear
Now that I have removed my run flats and the Mini has no spare, what make of canned air can have people used with good results?
Old Aug 29, 2003 | 08:47 PM
minicoop78's Avatar
minicoop78
I have used fix a flat in the past and it was fine
havent had to use it on the mini yet hope i dont have to that stuff sucks and tire guys hate it also be aware that the stuff is very flamable
Old Aug 30, 2003 | 10:57 AM
MGear's Avatar
MGear
Thanks minicoop78, I will take your advice, perhaps I should look at other brands as well?
Old Aug 31, 2003 | 03:15 PM
jimz68's Avatar
jimz68
How about carrying one of those 12v mini-compressors and a tire plug kit? I haven't had to use them, but a couple of friends have with good results. And, no slop in the tires. I have feelings for my brothers and sisters in the "industry". The gang at the tire shop our dealership uses hates canned the products.
Jim
Old Sep 1, 2003 | 06:02 PM
MGear's Avatar
MGear
Thanks or the suggestion, but I think I wil stick with canned air. This approach is not meant to be an all out repair, only a temporary patch to get you to the nearest station. I don't want to carry a small compressor in my mini, space is already at a premium.
Old Sep 2, 2003 | 12:15 PM
Alex@tirerack's Avatar
Alex@tirerack
>>Jim
Please as a courtesy let your tech's know if you have used fix a flat inside your wheels - its very difficult to get off the wheel.
I would let the tech know so he can put latex gloves on. Othewise he will become very sticky and upset - that goey stuff never totally dries!
Alex
Old Sep 2, 2003 | 04:16 PM
apexer's Avatar
apexer
Alex, Is there some solution that can be used to clean up the inside of tires & rims if you have used some brand of "Fix-A-Flat" and now want to plug from inside for a more reliable repair?
Old Sep 3, 2003 | 07:36 AM
Alex@tirerack
Using elbo grease and a good adhesive remover is the only way to remove fix o flat type sealent. I would most definatly get it out, and repair, or replace the tire.
Alex
chrisx18240
26
Mar 16, 2022 09:56 AM
theateist
Aug 22, 2015 06:58 AM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
M7Speed
Aug 6, 2015 01:48 PM
