Suspension Ireland Engineering camber plate noise?
Old Jul 25, 2008 | 09:39 AM
sprp85's Avatar
sprp85
I just wanted to see if what I am experiencing is 'normal'.
I have H&R coilover mated with a pair of ireland adjustable plates (Street) since last winter. It did not make any noise early this year (winter) but as the weather got hotter, it started to make 'pop' 'creak' 'grunt' noises when I turn the steering wheel at stop or at a very slow speed.
What could be the cause of the noise? Is it the hot weather? spring binding? Thank you all in advance!
Old Jul 27, 2008 | 06:37 AM
sprp85's Avatar
sprp85
I sprayed it down with some lithium grease and the noise got worse LOL
Old Jul 27, 2008 | 09:01 AM
Longboard110's Avatar
Longboard110
have someone move the steering wheel back and forth while you are looking at the area where the noise is coming from.
Old Jul 27, 2008 | 09:09 AM
Bang110's Avatar
Bang110
I would think just taking them off and checking everything would be the best bet.
Old Jul 28, 2008 | 08:40 PM
Mike87's Avatar
Mike87
I had the same problem once. It turned out to be the spherical bearings. I replaced them with higher quality ones and the problem went away. Call Ireland and say that you have a problem. They may do something for you.
Make sure that the bearings are tight in the bore. Use spacers if necessary.
Good Luck,
Mike
Old Jul 29, 2008 | 04:50 AM
chadtoolio's Avatar
chadtoolio
I got mine from DT and Chad got me a new bearing and shims from IE for the same thing.
W0TM8
Dec 19, 2019 07:50 AM
WestfaliaR
Aug 19, 2015 08:01 AM
Minibeagle
Aug 13, 2015 10:00 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
