Suspension Black rotors?
Old Jul 16, 2008 | 10:11 PM
MUShadd's Avatar
MUShadd
Black rotors?
just came across these on Alta's site. Does anyone have them? im just curious if the black actually holds up, or if it simply rubs off over time. these will go with my black and red theme very nicely.
http://www.altaminiperformance.com/p...es-Red-Drilled
Old Jul 16, 2008 | 10:14 PM
xnotfunkylex's Avatar
xnotfunkylex
Those look pretty cool.
Old Jul 16, 2008 | 10:21 PM
Ancient Mariner's Avatar
Ancient Mariner
Wilwood, to boot! Good stuff. That'll look great on your ride, Snypr.
Old Jul 17, 2008 | 10:57 AM
Kethian's Avatar
Kethian
Yes, the finish will disappear on the friction surface. It is just a black zinc coating similar to what EBC does on the domestic series of Sport rotors and on their Ultimax rotors. The hat and the edge of the rotor will stay coated though since the pad doesn't come in contact with them.
Those look great except that they appear to be cross drilled. Cracking around the drill holes? No thanks. Give me slotted or at the most dimpled every time.
That is a really bitching looking setup though
Old Jul 17, 2008 | 11:38 AM
hemiheaded18's Avatar
hemiheaded18
Well, they are Wilwoods so the chances of cracking are less than Ebay rotors but with such a design, the chance still exists. Here's another much less expensive option without going to a BBK:
http://www.txwerks.com/servlet/Detail?no=73
Old Jul 17, 2008 | 11:51 AM
Some Guy's Avatar
Some Guy
It appears that the holes have chamfered edges, so the chance of cracking should be lower that what it is with just straight up drilling.
Old Jul 17, 2008 | 07:51 PM
HighLife4136's Avatar
HighLife4136
If you're concerned with the cosmetic aspect of rotors, the high carbon content of these might lead to some rust. Not a performance detriment, but it doesn't look so hot...if you're concerned with that
Old Aug 27, 2008 | 08:21 AM
pimpedout97x's Avatar
pimpedout97x
so no one has tried these black rotors out?
Old Aug 27, 2008 | 10:44 AM
littlehandegan's Avatar
littlehandegan
Coordinator :: Low Country MINIs
Nylon them?
Old Aug 27, 2008 | 10:45 AM
pimpedout97x
LOL!
Old Aug 29, 2008 | 11:48 PM
Jason C's Avatar
Jason C
Originally Posted by littlehandegan
Nylon them?
Old Aug 30, 2008 | 08:10 PM
ninjlao's Avatar
ninjlao
Ninja Mini
Old Aug 30, 2008 | 08:20 PM
billzcat1's Avatar
billzcat1
Krautaholic is my former roommate. We exceeded our Comcast bandwidth limit in a big hurry the day of the red rotor thread. See also: Blue Tape S4 (mine lol)
Old Aug 30, 2008 | 08:33 PM
ninjlao's Avatar
ninjlao
Ninja Mini
haha that's awesome!
Old Sep 24, 2008 | 09:21 PM
cartar452's Avatar
cartar452
So has anyone tried these?
Old Sep 25, 2008 | 07:17 AM
txwerks's Avatar
txwerks
The finish on the swept area (where the pad contacts the rotor) will last approximately ONE stop. Same with cad plating, the black phosphorus coating on our rotors, etc. As far as drilled rotors, well, we don't use them (or recommend them), regardless of whether they were drilled or cast (which there is a huge debate about, anyway). Solid or slotted rotors FTW! All we ever run on the track cars is solid rotors...
The black anodized hat will stay black until you put them through a bunch of heat cycles on the track - then they'll turn a pinkish-black.
Old Sep 26, 2008 | 04:11 PM
jtack's Avatar
jtack
nice prep work on those red rotors
Old Sep 30, 2008 | 09:13 PM
donjulio's Avatar
donjulio
seriously, why make it black when they will fade in a couple of days?
Old Oct 2, 2008 | 12:48 AM
xnotfunkylex
HAHA I saw that blue tape s4 thread. It makes me want to do that to my car till this day.
Old Oct 2, 2008 | 12:18 PM
apexer's Avatar
apexer
Are the hats on the rotors "Floating" or is it a solid one piece rotor?
Old Oct 2, 2008 | 01:19 PM
billzcat1's Avatar
billzcat1
Neither. They are fixed two-piece rotors.
Old Oct 2, 2008 | 05:20 PM
apexer's Avatar
apexer
Ah. Third option I hadn't considered. Thanks
Old Oct 23, 2008 | 07:15 AM
toddtce's Avatar
toddtce
Originally Posted by SnYpR
Im just curious if the black actually holds up, or if it simply rubs off over time. these will go with my black and red theme very nicely.
This is now standard on all Wilwood SRP (combo drilled/slotted) rotors unless you specify (read pay more) for the standard zinc finish. The black is commonly called E-coat. This is an electro coating similar to powder coat but much thinner. (google it if you want all the specifics) It's done for two reasons; cost and enviromental issues.
Old Oct 26, 2008 | 02:19 PM
ne0lain's Avatar
ne0lain
I just got a set of those brakes from tce.. his customer service was great. Todd's got the best prices on the net.I took a couple of photos of the kit on my car, after a day of driving so you can see how they look.
Old Oct 26, 2008 | 06:30 PM
toddtce's Avatar
toddtce
Lookin' good!
I'm going to hijack the pics for the gallery too!
