Suspension Dinan Camber Plates intall?
I got my Dinan camber plates in the mail today. I was just courious if anyone has tackled this insall yet they say I have to pound out some studs
not looking forward to that... I know people are going to say why did I get these plates... Thats becuse Im Dinan Loyal...
Getting the rest of the suspension anytime soon? If you're going to drop the struts, you might as well do everything else.
I installed the Dinan camber plates on my car as part of the Dinan suspension package. You will need to pound out the bolts on the top of the OEM strut mounts. Following that, you'll use the supplied bolts to attach the Dinan plates to the top of the OEM strut mounts. IIRC, there should be written instructions supplied w/ the Dinan parts. Note, the front of your car will be raised very slightly with these plates in case you weren't already aware.
I don't believe so...the IEs include the top strut bearing as part of the assembly if I'm not mistaken. Imagine others can better comment, but think you'll need to remove the strut retaining nut (requires special tool) and compress the springs to do the IE plate installation.
Bang, once you put them in get to an alignment shop. Adding the camber plates screws up the front toe setting. You end up with a lot of toe in. Once it's done & aligned you'll ask yourself why you waited so long to install them.
Interior/Exterior Chrome strip above license plate, who makes black ?
got_mini?
Oct 7, 2015 02:12 PM
Oct 1, 2015 12:34 PM
Oct 1, 2015 12:28 PM
Oct 1, 2015 12:13 PM
