Suspension H-Sport Sway Bar - which hole is the softest setting?
Old Jun 18, 2008 | 02:19 PM
Robin Casady's Avatar
Robin Casady
I want to take it back to as close to stock as possible. Is this the hole at the very end of the bar? Currently, it is in the middle.
Thanks.
Old Jun 18, 2008 | 02:53 PM
mini-ff's Avatar
mini-ff
yes, you are correct.
Old Jun 18, 2008 | 03:16 PM
old81's Avatar
old81
M6
Robin,
I believe we have the same bar 19mm, 3rd hole out on the end is as near to street as your going to get.
I am running mine in the middle, no issues. It suits my driving style and flattens out the sway I was getting with the stock suspension.
Sorry to see you had a excursion with your MINI, you are ok other than frustrated with your swaybar?
Don
Old Jun 18, 2008 | 05:31 PM
Robin Casady
Thanks. It isn't frustration quite as much as realizing that my driving skills are not up to that much oversteer. I'm OK. Only the MINI was injured.
Old Jun 18, 2008 | 06:25 PM
old81's Avatar
old81
M6
Good, when do you get the MINI back from the shop or do you have it back now?
Are you going to have to redo all the custom cabinet work? I imagine you had it anchored well and everything survived.
Old Jun 18, 2008 | 06:31 PM
PlayPlay's Avatar
PlayPlay
OH NO! I'm very sorry to hear about this. I've been following all your threads Robin because I just bought a rear sway myself so was reading all your posts and questions. Very sorry that it didn't turn out the way you thought it would! I'm getting my installed tomorrow and now I feel like perhaps I need to set it to middle instead of full stiff.
Old Jun 18, 2008 | 07:04 PM
old81's Avatar
old81
M6
Play, not full stiff unless you want to rotate. I would reserve full stiff for track days or a tight AUTOX.
My friend and I discussed this the other day, he likes to drift his track cars in the sweepers and rotate in agressive turns on the track. I suggested he go with a 22mm on full stiff.
He ordered the 09 JCW HARDTOP with base suspension, since he will be doing some road driving, so the 22 will be on full soft for around the interstates and on full stiff for track.
As well as suitable tires and wheels, of course.
Mini7
Feb 2, 2016 07:52 PM
minipopkart
Aug 13, 2015 05:22 AM
nomar116
Aug 10, 2015 11:24 PM
ClayTaylorNC
Aug 10, 2015 09:19 PM
