Cooper and Cooper S - Total Ignition Upgrade Coil, Wires, an
Old Aug 19, 2003 | 06:40 PM
MiniPilo's Avatar
MiniPilo
New Pilo Racing Package
The Cooper and Cooepr S 2002+ Total Ignition Upgrade.
Parts Included:
40,000 Volt Coil Pack,
8.5mm Plug Wires
U-grove Spark Plug
Information:
Coil Pack
This is a true performance coil pack. The stock coil puts out 36,000 volts under heavy load, but the Pilo Racing Package puts out a shocking 40,000 volts under heavy load. The voltage increase is enough that plug gaps need to be opened up to .065 inch. This hotter spark will now travel through more fuel and air making a better burn in the combustion chamber. Be sure not to mix up the plug wires when installing your coil. Because of the increase spark we recommend you install a good quality plug wire at the sametime you install the coil. This coil carries a full 1 year warranty.
8.5mm Plug Wires
These 8.5mm wires only are 25 ohms resistance per foot , double-silicone, reactive-core design reduces RFI (Radio Frequency Interference) that can disrupt on-board computer and audio equipment function and performance. Ready to install custom sets for your MINI.
U-grove Spark Plug
ACCEL spark plugs are the only plugs manufactured exclusively for high performance street and racing engines. The product is the standard heat range or available in a colder range for pulleyed cars.
Price: $132.00
Old Aug 25, 2003 | 04:09 AM
MiniPilo's Avatar
MiniPilo
Update:
Products are in stock, and shipping now!
Teh
Aug 22, 2022 04:37 AM
Dec 23, 2015 10:36 AM
Trevor413WC50
Aug 18, 2015 10:38 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
