R50/53 My air filter housing- fit seems odd?
Old Jun 14, 2008 | 01:11 PM
beemer2002's Avatar
beemer2002
I was checking the air filter today in my 02- non-S and noticed one side has two screws, the other has no tabs, clamps, etc and has a bit of a gap. Is this normal? I don't see any evidence there were any way to button down the other side. Any thoughts?
Thanks!
2002 MC
Old Jun 14, 2008 | 07:52 PM
Some Guy's Avatar
Some Guy
If by other side you mean the part by the firewall, there are some tabs back there that hold it down, they are just very hard to see without pulling the airbox cover off.
Old Jun 14, 2008 | 10:33 PM
Ancient Mariner's Avatar
Ancient Mariner
02 non-S has molded plastic hooks on the lid and square loops on the passenger side of the box. They break off. I replaced mine with some brass (steampunk look) snap latches to hold it down tight while retaining the screws on the drivers side. Then I replaced it with a CAI. No hooks, no loops, no latches, no screws.
Old Jun 15, 2008 | 08:09 AM
beemer2002's Avatar
beemer2002
THANKS! Those hooks/loops must break off clean. Thanks for your help. Can you elaborate on what CAI is?
Old Jun 15, 2008 | 08:55 AM
Xymox's Avatar
Xymox
http://en.wikipedia.org/wiki/Cold_air_intake
Old Jun 15, 2008 | 08:56 AM
Ancient Mariner
Yes, they do break off clean. The part on the box if memory serves.
CAI is cold air intake. Replace the filter and assembly with an open cone-type filter (K&N, etc.).
Old Jun 15, 2008 | 09:52 AM
beemer2002's Avatar
beemer2002
Thanks again! I've been looking at them, but not sure what to get. What kind is the one you've pictured? I will need the OEM for cold seasons in MN, so don't want to do anything non-reversible. I though cold air intakes imply the filter is sucking air outside the engine compartment? THANKS!
Old Jun 15, 2008 | 11:13 AM
lordgrinz's Avatar
lordgrinz
I changed the filter on the MINI I picked up yesterday, took me a few minutes to realise I had to remove that cover on the cooler for the supercharger to get the air filter cover out of my way to remove the air filter and clean the chamber. But yeah those tabs are small and hard to make sure are secure when reattaching.
Anyone know why the air filter would have a slightly oily feel to it on the dirt catching side? I assume it might be road grime from the intake, but thought I would check here for advice.
Old Jun 15, 2008 | 12:47 PM
Ancient Mariner
Most of the aftermarket CAI's are easy to swap back and forth to the OEM.
The one pictured is mine built from scratch (except for the filter cone, of course). I'm a tinkerer.
Old Jun 15, 2008 | 04:37 PM
beemer2002's Avatar
beemer2002
Thanks again..do you also have an 02' non-S? If so, would you consider creating another that I would buy from you? What would it cost? Thanks!
Old Jun 15, 2008 | 07:54 PM
Ancient Mariner
Yeah, '02 no-S, barebones. No, none for sale. Like I said, I'm a tinkerer, and I'm constantly changing the design while striving for small improvements so I really never have a finished product.
I seem to take more pleasure in the creation rather than the completion...
Old Jun 17, 2008 | 04:34 PM
beemer2002's Avatar
beemer2002
I just bought an AFE 54-10561 CAI, should have it by next week. I'll post my experience as soon as I test it out..thanks for your input!
Old Jun 18, 2008 | 06:13 AM
beldingsfinest's Avatar
beldingsfinest
Silly question, but I can't find it anywhere:
Where is the intake air filter? I have an '05 MCS and just changed the oil on it last night myself and was going to replace the air filter with a FRAM CA9806 that I bought at the same time. Anyone have pics, or can you direct me to another post?
Thanks!
-ZB
Old Jun 18, 2008 | 06:33 AM
Xymox's Avatar
Xymox
Thanks!
-ZB
You really can't find it? But managed to change your oil?
It's to the right (driver's side), just behind your engine. You'll have to gently pry the ridiculously engineered hose clamp off, slide the battery (+) point off the airbox, and then using a hex screwdriver, unscrew the two screws from the top of the airbox.
Old Jun 18, 2008 | 06:49 AM
beldingsfinest
OK. Thanks, I should be able to get that taken care of tonight!
Old Jun 18, 2008 | 07:08 AM
lordgrinz's Avatar
lordgrinz
I resorted to taking the cover off the intercooler, it was only 4 screws, then the air filter cover could be moved out of the way without taking the hose off.
silence2-38554
98
Sep 21, 2016 02:52 PM
polotska
Aug 23, 2015 09:10 AM
minipopkart
Aug 13, 2015 05:22 AM
M7Speed
Aug 6, 2015 01:48 PM
