Suspension End Link upgrade
Old Jun 6, 2008 | 05:40 PM
Malcon's Avatar
Malcon
End Link upgrade
How recommended is the endlink upgrade for the sway bars??
I have to replace the passenger side front one... but I'm thinking maybe upgrading to the alta set...
anyway
any thoughts??
Old Jun 6, 2008 | 06:22 PM
onasled's Avatar
onasled
Malcon, what other suspension changes have you made? If it's just a swaybar then a factory link is just fine. If you have the $$ to spend on a set of adjustable links and just have to have them then there are way better ones out there then the Altas for the front bar. Altas are fine for the rear though.
Old Jun 6, 2008 | 07:59 PM
AutoXCooper.com's Avatar
AutoXCooper.com
You could do all four with TSW end links and balance the car out for more neutral handling. http://www.autoxcooper.com/tsw_suspension.html
Old Jun 6, 2008 | 08:09 PM
hemiheaded18's Avatar
hemiheaded18
What about with a lowered car and a sway bar? Are upgraded links a better idea then?
Old Jun 7, 2008 | 11:34 AM
brownflyer's Avatar
brownflyer
Malcom,
I couldn't agree more with Onasled!! Don't go Alta in the front. Rears are fine. Stick to stock or look for different ones.
Originally Posted by onasled
... If you have the $$ to spend on a set of adjustable links and just have to have them then there are way better ones out there then the Altas for the front bar. Altas are fine for the rear though.
Old Jun 7, 2008 | 03:18 PM
minimarks's Avatar
minimarks
Powergrids (TSW, WMS) here and after lowering and driving for a while without them and then putting them on, they make a very nice change. The car is better balanced and settled with more forward bite. PS: I did all four.
Old Jun 8, 2008 | 03:22 AM
etalj's Avatar
etalj
The stock endlinks cost me 60 dollars a pop, so why not pay 155 for 2 ? or 300 for 4? I think these are great value, and are great for balancing the car nicely. I have four powergrids (TSW) and they are highly recommended
Old Jun 9, 2008 | 07:17 AM
MINIdriver85's Avatar
MINIdriver85
With rear 22mm sway bar and JCW shocks and Eibach springs (soon going for a set of BC Racing coilovers) do you recommend adjustable endlinks both front and rear?
Old Jun 11, 2008 | 07:17 PM
PlayPlay's Avatar
PlayPlay
Funny, I was just looking at endlinks since I just bought a rear sway. Anybody have the Helix endlinks? What makes TSW better? Thanks...
Old Jun 11, 2008 | 08:44 PM
minimarks's Avatar
minimarks
Heim joints are just not as good in day to day driving as the better sealed and better articulation that you find on the TSW (powergrid) endlinks. My 2 pennies.
Old Jun 12, 2008 | 03:32 AM
etalj's Avatar
etalj
I'd definately recommend them, even without coilovers, but with your new BCs, i think you should definately have. You can't properly corner-balance the car without adjustable endlinks (i'm assuming you want to corner-balance)
Old Jun 12, 2008 | 04:03 AM
MINIdriver85
Were ou responding to me? If yes, my first worry (and reason why I was looking into adjustable endlinks)was to have zero preload...
Old Jun 12, 2008 | 05:54 AM
minimarks's Avatar
minimarks
Corner balancing = zero preload unless you are wanting to load a corner for a specific turn, track.
Old Jun 12, 2008 | 06:06 AM
meb's Avatar
meb
Looking at minimarks' comment in reverse - sort of - a stock mini will have some pre-load as soon as you sit in the car. A corner balanced car will not have preloaded endlinks once you sit in the car.
Old Jun 12, 2008 | 06:40 AM
onasled's Avatar
onasled
Really, unless you are using the car more then 50% of the time on the track, corner balancing is a huge waste of time. Even then, to corner balance any car that is not a full time track car is throwing money out the window.
Some comments here on how just adding adjustable endlinks have made a noticeable difference in the cars handling. Maybe those that have done so can explain just how and why they come to this conclusion.
Unless you have really messed up your ride heights when adding adjustable ride height coilovers, then the amount of preload you might get without adjustable links is not mountable to much.
Now, absolutely nothing wrong with getting adjustable endlinks at all. I did it when the car was still streetable. But I just don't want those that are uncertain on the importance of them to think that they will really doing much help on a car that is not track dedicated.
Added this: Adjustable links will help if you ever 'stagger' your adjusments from side to side. Like when using the last hole on one side and the middle hole on the other.
One more note, of course all just "my" opinion. Don't ever preload a Mini's swaybar for any track. Just the wrong thing to do. If you are going that far in your thinking then it's time to by new springs.
Old Jun 12, 2008 | 04:21 PM
etalj's Avatar
etalj
Yeh i was indeed.
Corner balancing is very much a fine-tuning, but its not necessary. However, i do believe that they are a good idea for either street or track use, as it allows the preload to be zero on the swaybars (once you've sat in it). The swaybar's work at their best with 0 preload.
Old Jun 12, 2008 | 04:37 PM
minimarks's Avatar
minimarks
Guess you could ask if you were in a race and your a last place car and you put endlinks on and corner balance it, would it make you a first place car? NO, but it will make the car more predictable, better balanced and allow you to work on the mod between your ears. Which by the way, I need a lot of work on...
Old Jun 12, 2008 | 05:24 PM
onasled's Avatar
onasled
Don't confuse corner balancing and adjusting for zero preload as the same thing. Completely separate from each other. Yes, adding any preload will throw off a corner balanced car.
Just don't corner balance a street car. It's 99% a waste of time and money.
Old Jun 12, 2008 | 06:16 PM
jhiggs26's Avatar
jhiggs26
I tried to PM you Onasled. Do you have time to clear some PM space?
Jeremy
Old Jun 12, 2008 | 06:22 PM
minimarks's Avatar
minimarks
Wasn't, but I'd like to hear your discription and advice.
Old Jun 12, 2008 | 06:41 PM
onasled's Avatar
onasled
Was addressing the post above yours. Yours was clear and pretty accuarte I think.
Old Jun 12, 2008 | 06:42 PM
onasled's Avatar
onasled
Jeremy
Will do. Gimmi about 10 min.
Old Jun 12, 2008 | 07:32 PM
minimarks's Avatar
minimarks
Old Aug 7, 2008 | 09:54 AM
SparklingMini's Avatar
SparklingMini
I have an unrelated question. I just put the JCW suspension kit on my car thinking it would take care of an issue that the dealer believes is in my head.
After taking a few corners...not hard mind you it seems at times, the rear suspension is a little unbalanced more lean on the driver’s side, but corrected after I do a left turn or two...what could cause this. It is not as noticeable now that the stiffer suspension in installed but I still recognize it.
could the cause be flex or movement in the rear struts etc? I welcome any suggestions.
Old Aug 8, 2008 | 01:45 PM
txwerks's Avatar
txwerks
IMHO, the preload on the swaybars using the fixed-length OEM endlinks is a likely culprit. I noticed much, much more neutral behavior, better behavior in quick transitions, and more lateral grip even on a "stock" style suspension (Bilstein SP's with our TSW springs).
