R56 Bigger Turbo on Stock MCS?
I am looking for some usefel infomation on upgrading or swapping out the stock "mini" turbo for a bigger turbo with a little bit more ballz....?
What do you guys recommened and is it worth the extra bucks...?
Any info is helpful to me!!
Paul
Paul
Alta developed a kit with a GT-25 turbo. Go post in the Drivetrain section and ask about it, maybe you'll get lucky and Alta will give you more info on it, they've been awfully quiet about it.
You will need to also pay attention to the injector size, how much boost the injector duty cycle can sustain below 100%. Also, the amount of power the stock clutch/tranny is capable of handling. If it is an auto of course...how much that tranny can sustain.
I have a decent background tuning turbo cars and power is not an issue, the problem lies with all the supporting components. Another option you have is raising the boost. An easy mod such as a boost controller could yield a lot of power however...again...it is all relative to what the car can handle all together.
Good luck!
Good luck!
Dec 5, 2016 06:31 PM
Drivetrain removing heat shields for turbo cat ?
rckrzy1
Aug 11, 2015 06:06 PM
