R50/53 Sparkplug Type?
Old May 30, 2008 | 05:31 AM
05Greenie's Avatar
05Greenie
Sparkplug Type?
I have 77.5k miles on my 2005 MC and I'm going to change out the sparkplugs, do I replaced with OEM NGK plugs or is the NGK iridium plugs better?
Also is there a specific process to changing out the plugs, I have changed out plugs before, but wanted to know if any special tools are required.
Old May 30, 2008 | 07:07 AM
nobogez07's Avatar
nobogez07
I used iridium plugs in my 04 S and had all kinds of problems with them. They burn too hot!! I replaced them with standard NGK's and the problem went away!!
Old May 30, 2008 | 07:46 AM
hemiheaded18's Avatar
hemiheaded18
http://www.partsamerica.com/ProductD...pe=960&PTSet=A
Just go with the OE plugs. Playing with different plugs can end up costing $$$ that you won't see any improvement in and can occasionally cause problems. Granted, I've sold everything from copper Autolite's to $10 a piece iridium Bosch's and have had no come backs with either but in this case, err on the side of caution and go OEM.
Old May 30, 2008 | 12:16 PM
05Greenie's Avatar
05Greenie
Thanks to everyone who replied.
Good information...and I'll replace them with OEM plugs.
Happy Motoring
Old May 31, 2008 | 10:00 AM
Nitrominis's Avatar
Nitrominis
Ditto
Although I am a bit on the radical side and use *AC Rapidfires I would always recommend the OEM plug and heat range. The exception if you are going to do proper plug readings to detirmine how the plug is reacting in the combution chamber. *Lots of trial and error.
RobbyD
Jan 29, 2019 01:22 PM
IrishMCS
Dec 1, 2015 04:21 PM
FatherG
Sep 24, 2015 08:56 AM
GregoryK
Sep 10, 2015 10:54 AM
Sep 4, 2015 03:56 PM
