225/40/18 tires~
Old May 25, 2008 | 01:26 AM
oskai's Avatar
oskai
225/35/18 tires~ have u tried it?
Edit:
Hello ~
Will 225/35/18 fit for 18X7.5 45 offset work? Will it rub....Have anyone tried it before? Please let me know~ Thanks!!
Hello
I got some new wheels with 45 offset. Its 18X7.5. I know the best choice is 215/40/18...but the 225 is so much cheaper...So i want to know does it ACTUALLY rub? Because i searched the forum and ppl just say it MIGHT rub....has anyone tried it before? my car is stock R56 MC....
Thank You!!
Old May 25, 2008 | 10:06 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Originally Posted by oskai
Hello
Thank You!!
225/40-18 fits rims 7.5 to 9 " wide, 25.1" tire diameter.
Rubbing is likely but not impossible to make it work.
Be prepared to-
Do a little trimming of the rear inner wheel well plastic.
Increase rear negative camber using adjustable rear lower control arms
Not invite passengers to sit in your rear seat.
You do get a little speedo error.
When speedometer reads 60mph (96.6km/h) actual speed will be 61.5mph (99km/h): 2.5% faster.
Old May 26, 2008 | 12:30 PM
oskai's Avatar
oskai
hey mini hun~ do u know if 225 35 18 will rub...? Thanks!!
Old May 26, 2008 | 12:43 PM
minihune's Avatar
minihune
225/35-18 fits rims 7.5 to 9" wide, perfect for 8" wide rim, 24.2" tire diameter and comes in Goodyear Eagle F1 Asymmetric, Max Performance Summer tire.
225/40-18 is too tall.
225/35-18 is slightly smaller than stock tire diameter so clearance would be better. You just need a rim that is 18x7.5" or wider which is what you were going to use.
So 225/35-18 should work with stock suspension and with a mildly lowered MINI.
Old May 26, 2008 | 10:07 PM
oskai's Avatar
oskai
Hello Minihune
hmmm will it work with a wheel that has 45 offset ? Thank you so much for ur info~!!!
Old May 26, 2008 | 10:20 PM
flingger's Avatar
flingger
Mine rub!
Old May 26, 2008 | 11:28 PM
oskai's Avatar
oskai
but u had 225/40/18 ...thats too tall...i am worry about the width....but thank you for replyin!
Anyone experience rubbing with 225/35/18 though? Please Help!!
Old May 26, 2008 | 11:32 PM
minihune's Avatar
minihune
Correct. +45mm offset is good.
225/35-18 is OK with 18x7.5 wheel as you already stated.
225mm wide tires are no problem.
Old May 30, 2008 | 09:31 AM
dri's Avatar
dri
good information. i'm a new mini owner so i kinna need these specs. i'm planning to get a set of wheels from a friend, it's:
4x100
225/40/18
et 42
u said 225/40/18 is too tall. u mean it's too tall for the car (will rub) or it would make the car looks taller...
Old May 30, 2008 | 11:37 PM
oskai's Avatar
oskai
i think the 225 40 18 will be too thick and rub the fender...? But i am not sure...my final choice was 215 40 18.....even though i want to go with 225 35 18....i just want to be safe since i ordered the tires through online....
hopefully someone can help u! and have fun driving the Mini
Old May 31, 2008 | 10:21 AM
minihune's Avatar
minihune
4x100
225/40/18
et 42
225/40-18 is too tall to fit a MINI. The tire diameter is 25.1" and stock is about 24.3".
Using a tire that is too tall will decrease clearance in the wheel well so that the tire will rub the inner black plastic wheel arch in the back.
Also a tall tire will decrease wheel gap and look too tall for the MINI, the porportions will be out of balance. You can increase tire diameter to about 24.6 or 24.7" and make it still fit but beyond 25" is too tall.
225mm width is not usually a problem if you have enough wheel offset that is low in number to push the tire outward for clearance but with the tire being tall you won't clear the wheel arch liner.
215/35-18 fits rims 7-8.5" wide, perfect for 7.5" rim, 23.9" tire diameter.
215/40-18 fits rims 7-8.5" wide, perfect for 7.5" rim, 24.8" tire diameter.
Waszak
Oct 21, 2017 05:55 PM
dpike
Sep 12, 2015 08:19 AM
Tires, Wheels & Brakes
Sep 9, 2015 11:08 AM
Ntety
Sep 2, 2015 08:39 PM
