R50/53 It is necessary to clean the intercooler?
It is necessary to clean the radiator?
Hi all,
1. It is necessary to clean the top part/all radiator (please refer to the photo) ?
2. How do we clean it - soap water + water + let it dry?
3. How to take it out? Shd be easy job?
(Hope Der Abt dont mind I used his car photo)
Thanks alot
Thanks alot
Intercooler
Uh, that's the radiator. You own a Cooper and it doesn't have an intercooler.
Just take it to a car wash and blast the bugs out of it if you want to.
Lightly soak the radiator with a trickle from your garden hose. This will make all the dead bugs loosen up and less likely to stay stuck to the radiator. Then use your shop vac to suck them out, (avoiding contact with the vanes of the radiator; don't want to bend them...)
Next time you go out to dinner, remember to pick up some toothpics, especially if they are the round type.. Mint doesn't matter!
They work wonders for removing radiator bugs but they are also good for reshaping any vanes that aren't as straight as they used to be.. This works very welll. and in most cases it'll be as good as new.
Jim
They work wonders for removing radiator bugs but they are also good for reshaping any vanes that aren't as straight as they used to be.. This works very welll. and in most cases it'll be as good as new.Jim
Jim
Now I KNOW you wouldn't use toothpicks when this tool exists:
http://www.toolrage.com/prodView.asp?idproduct=15
Ken
Ken
, check this out:I hope this link works, this is hilarious:
http://www.youtube.com/watch?v=c-Lnfpulwjc
Wonder if we could do this with 2 Minis
What about the intercooler inside? should we tear apart the intercooler and clean the sludge build up inside. just wondering if that would work instead of a oil catch can? i still want a catch can but should i do this before i put it on?
Just be sure to rinse out all of the soap!
Ahh, how long have you been driving automobiles? Might want to lay of the "vodka" for alittle while
