R50/53 How to lock the car without the key?
Is there a simple way to lock up the car when you don't have the key with you? I tried opening the driver's door and then pressing the lock button in the door down before closing it, but the button won't budge with the door open. (I didn't try it with the passenger door, though).
I tried that, but with the car off, it didn't appear to do anything. Plus, I'd have to do it with the door open so that I could actually get out of the car afterward, and the doors seem unable to lock while they're open (at least, the lock button on the door won't move down if the door's open).
I can't check it now, because I just sold my 2004 to get my 2008. I remember that if you lock the driver side door from the passenger side and then lock the passenger and close the door, the doors will remain locked.
you can not lock it with the driver door open, you can however lock it with the driver door closed and passenger door open. also if your windows are down and even if the dirvers door is unlocked you can not reach in and unlock the passenger/hatch unless you open the driver door
I think you could while inside the car lock it with you inside, then climb into the back and kneel in front of the rear seat and lift it up and pull the emergency boot releae, then open the boot and climb out and close...it will remain locked,..... I think.....easy
you lock it, unless you lock it "twice" and disable the motion detector.
It will also go off when you open the boot.
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
