First Mods
First Mods
hey i have a cooper '03 and was just looking for some ideas on what to mod first.
Everything is stock right now.
Im looking more along the lines of prolonging the car's life hopefully, cause it is getting old.
Not too concerned in huge speed boosts yet.
Not sure about mods for prolonging the life of your Mini, but I just did a K&N drop in filter. Next I hope to do a Megan Cat Back followed by a tune. I am also not looking for huge power, just to round out the performance and get a better sound.
Any decrease in reception?
I have never run into any problems with cat backs put one on every new truck I have owned. This is my first car in 15 years.
leicaguy:
In Toronto our radio signals are rather strong since we have flat terrain and all signals come from the CN Tower quite high above the city. The only reception change is I have no signal below 3 floors down in underground parking, whereas with the stock antenna I had no signal below 4 floors down.
Very easy change, you just unscrew the stock antenna and screw on the new one.
i would start off basic on the mods (cai,exhaust) and see how your mini takes them...just slowly work on it...mines an 03 with 69k(woo) miles on it and so far so good (intake,exhaust,pulley+more)
whats the diff in replacing the rubber
and im considering in getting a CAI and exhaust soon, so any recommendations in what to look for?
thanks for the replies everyone, much appreciated
CAI or HAI, Exhaust, Stiffer rear sway bar, lighter wheels, better tires
Lowering springs, fixed camber plates
Koni FSD struts or Megan coilovers if you're on a budget
Your biggest issues will be tranny failure if you're got the 5 speed, and potentially power steering pump failure causing a fire.
Tons of little mods you can do as well like the Fumoto valve if you change your own oil, brass bushing mod for better braking performance, better brake pads for less dust and better performance.....
Richard ('03 Cooper & '05 Cooper S)
if you want sound, Alta.. cravens.. and so on are the way to go.
if you want everyday drivability, performance with a bit of extra sound, JCW is the way to go.
If you can find them the Dinan CAI's are generally thought of as fairly quiet (aka daily driveable) while still doing a good of being a CAI. They are cheaper than the JCW and also look pretty factory.
Manual or CVT transmission?
Which interior? Cloth, leather or leatherette?
Stock stereo or Harmon Kardon?
Which stock wheels? 16x6.5 X-lytes or 17x7 S-lytes?
Which tires do you have- runflats or non runflats?
Name and size of tires you have now? How much tread left?
Do you have any snow or use winter tires? Any colder weather, or rain?
List your responses-
In any case, easy mods:
Drop in Air filter- clean one- K&N, Green, Alta or Unifilter.
One Ball Exhaust mod for the MCS.
Whalen shift **** for any manual transmission
Lighter wheels- 16x7 +45 offset and non runflat 205/50-16 Ultra High Performance tires.
Carbotech brake pads-https://www.northamericanmotoring.com/forums/showthread.php?p=2236421
Next, I'm going to tint my rear windows and back window!
