Suspension Factory camber and toe settings - anyone know?
Old May 20, 2008 | 05:47 PM
BobinPhilly's Avatar
BobinPhilly
What are the ranges of the factory specified front and rear settings for both camber and toe (out or in) for an R56 with factory sport suspension?
And, if those factory settings are specified in degrees, what's their equivalent in fractions of an inch (or the formula to convert them)?
Thanks.
Old May 20, 2008 | 11:05 PM
Robin Casady's Avatar
Robin Casady
Faxed to me from a dealer.
"Wheel Alignment R56 Sports suspension, not low-slung"
Front Axle:
Total toe: 0 deg. 12' plus or minus 5'
Camber: -30' plus or minus 25'
Rear Axle:
Total toe: 0 deg. 24' plus or minus 08'
Camber: 1 deg. 45' plus or minus 20'
Old May 21, 2008 | 11:49 AM
BobinPhilly
Front Axle:
Rear Axle:
Robin:
Thanks for the info., above, but the technical shorthand is a bit beyond me.
1. For front axle camber, what's the "deg. #" that comes before the plus and minus info.?
2. Do the apostrophes after the various numbers represent "degrees?"
3. Would it be correct to also state the front total toe as ranging from .12 degrees in to .05 degrees out?
4. Would it be correct to also state the rear camber as ranging from positive
4.5 to negative 2.0?
Thanks, again.
Old May 23, 2008 | 07:18 AM
TerryD's Avatar
TerryD
Translation. Angles are measured in degrees, minutes and seconds. 1 degree = 60 minutes and 1 minute = 60 seconds. minutes are designated with a ' and seconds are designated with a ".
The factory spec you mentioned for the front (-30') is -.5 deg. with a range of just under -1 to just over 0 (in a negative direction. (The rear is roughly -1.75 to -1.5)
AdrenaliNate
Aug 24, 2015 12:37 PM
Minibeagle
Aug 13, 2015 10:00 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
