R50/53 Glove box headache.
Old May 20, 2008 | 10:38 AM
Bang110's Avatar
Bang110
Glove box headache.
I posted this issue a while ago. I got lots of responces. The problem I am having is that the glove box pops open on bumps. People told me that there are screws to adjust the bar where the latch grabs on. I went the other fday to adjust it and there are only little bolts holding it in. So I tried to adjust it and no luck. It's like the bolts just turn and don't get loose or tight. Doesn't seem to me at all that it's adjustable.. Arg.. Do I need to take the glove box out to adjust it?
Old May 20, 2008 | 01:48 PM
JIMINNI's Avatar
JIMINNI
Thats what I did, it's not that hard. Then you will see that it is adjustable, back and forth. I actually ground the latch down alittle so it hangs lower. Has been working great .
Old May 20, 2008 | 02:01 PM
Bang110's Avatar
Bang110
Well damm.. So the little bolts I can see inside the box dont adjust it? Have to take the box out to do it? I hope not. I just re did alot of things and dont want to have to take it all back out. I covered the down tubes with suede, put a pad under the suede on the drivers side and also ran all the wires for my Sirius radio in the pass side tube.
Old May 20, 2008 | 03:49 PM
Mini-RI's Avatar
Mini-RI
I had this problem on my '03. I did a search and found an easy fix - only took a few minutes.
Here's the link to the fix:
http://nemini.org/index.php/topic,2747.0.html
Old May 20, 2008 | 08:19 PM
Bang110's Avatar
Bang110
Thanks for that link! I thought it was just simple screws holding the little latch bar in place. I guess I will take the box out again and adjust it. It sure is annoying going over bumps and having that thing fling open.
minimofo
Dec 26, 2015 12:03 PM
JamesDeBart
Nov 16, 2015 06:51 PM
pglgp1292
GP Talk (2006)
Oct 2, 2015 10:34 AM
simo711
Oct 1, 2015 05:36 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
