R50/53 Best place for a clutch
Old May 20, 2008 | 06:23 AM
blkkouki's Avatar
blkkouki
ok guys so im in the need for a new clutch after 60k its making nasty noises at take off. where is the best place to buy an aftermarket clutch, something stronger then oem, stage 1 or 2
thanks
chris
Old May 20, 2008 | 06:26 AM
sequence's Avatar
sequence
depending on that nasty noise at takeoff, it might be yr dual mass flywheel that's defective or worn, and not the clutch, and since U cant turn a DMF that should be replaced with the clutch--but then we dont know what kind of MINI U own: regular coopers have regular flywheels while S's have the DMF. More info is needed here.
Old May 20, 2008 | 07:22 AM
ScottinBend's Avatar
ScottinBend
"Best place for a clutch"..........is probably between the tranny and the engine?
Sorry, couldn't resist it...............
Old May 20, 2008 | 07:34 AM
kgardnez's Avatar
kgardnez
It's too bad you don't want OEM, someone has one for sale in the marketplace (I've been thinking about buying it as a "just in case").
Old May 20, 2008 | 07:39 AM
thatatvguy's Avatar
thatatvguy
That was a good one.
There have been lots of posts about which one is "better".
Exedy, Fidanza, Spec, Clutchmasters, etc. It depends on your setup and what the future plans are for your car. But, anything, probably is better than stock. Shop around.
Old May 20, 2008 | 07:55 AM
blkkouki's Avatar
blkkouki
sorry its a 04 mcs with the basic mods, m7 cai, milltek header, milltek catback, m7 16% pulley but going to put a 17% on soon
Old May 20, 2008 | 09:52 AM
lawmann's Avatar
lawmann
Coordinator :: Middle Georgia MINIs
Clutch
I have a question, just having my clutch replaced a few months back with only 28,000 miles on it (and I drive pretty normal). Will converting from a DMF to a solid flywheel cause adverse issues with a MCS? I now have 39,000 miles on her and am looking at ways to extend the life of the various parts I replace in the future. I'm not a big fan of the DMF used on the 04-06 MCSs, there have been quite a few in the club that have already had to have the DMF and clutch replaced.
Old May 20, 2008 | 12:02 PM
Ancient Mariner's Avatar
Ancient Mariner
Read somewhere on the interweb (don't remember exactly where/what) that the main reason BMW went with DMFW was to quiet down the transmission some. The Midlands, I'm thinkin'. Not so much for any performance/mechanical reasons, but it was a couple of years ago and the wet-ram is losing some retention. Time for an upgrade.
Footnote: The DMFW is also designed to insulate the tranny from vibrations and shocks from the engine. The internal springs are tuned to a particular engines torque curve and are not overly fond in torque/hp increases. Early failure can ensue. But then, you don't look like you've fiddled with the engine.
Old May 20, 2008 | 12:17 PM
blkkouki's Avatar
blkkouki
well ive found one called SPEC they seem pretty decent priced 300 shipped on ebay, doesn anyone have any take on these and a lightened fidanza flywheel
Old May 20, 2008 | 01:40 PM
Nitrominis's Avatar
Nitrominis
Check with Jan RMW on a clutch. http://www.revolutionmini.com/clutches.html
He has the best prices for an after market clutch. Also he is a vendor here on NAM
www.RevolutionMini.com
949-456-9590
jarymo
Hawaii MINI Motoring Club
Sep 30, 2015 04:19 PM
Quixotic1
Sep 11, 2015 11:15 AM
wildwestrider
Sep 4, 2015 06:25 AM
Sep 3, 2015 02:06 PM
