Which Pump Do You Recommend?
Old May 19, 2008 | 06:47 PM
PlayPlay's Avatar
PlayPlay
I ditched the run-flats long ago. But, I don't yet carry a pump/patch kit.
I'm considering two:
http://www.tirerack.com/accessories/...tkit/index.jsp
and
http://www.outmotoring.com/mini-coop...ility_kit.html
Which do you think I should get? Anybody have good/bad experience with these? Any other recommendations?
Thanks in advance...
Old May 19, 2008 | 07:00 PM
gregdconsulting's Avatar
gregdconsulting
I picked up a 12v pump for $10 at Wal*Mart. It has a gague and worked when I needed it. I thought of spending more and looked at others, but they all looked pretty much the same. I have a Dynaplug kit and some pliers too to pull nails as part of my flat repair kit. I still have the runflats, but will probably get non RF if I can decide on a wheel.
Greg
Old May 19, 2008 | 07:23 PM
tony1athome's Avatar
tony1athome
I picked up the Slime kit, including pump, at Target for about $20.
Old May 20, 2008 | 06:54 AM
Diploman's Avatar
Diploman
The Conti kit is somewhat expensive, but it works very well. My MCS has yet to experience a flat, but I've used the Conti pump on a couple of other cars. One of them is still running - untouched - on the latex sealant repair almost six months after I pumped it up. Tire Rack carries the replacement cartridges for the sealant which must be ordered whenever you use the pump. It's an effective and easy-to-use setup. For insurance, I also carry a Dynapug kit.
Old May 20, 2008 | 07:00 AM
MirthScout's Avatar
MirthScout
I got the Conti kit too. I really wanted it to fit in one of the side compartments in the boot. It didn't fit. So I got one of the Slime kits. The pump (just barely) fits in one of the side compartments and the slime and some misc other stuff fit in the compartment on the other side.
Old May 20, 2008 | 11:59 PM
amazingrando's Avatar
amazingrando
Auto on Sport Button guy
Just picked this up today as well along with a digital tire pressure gauge.
Still need the plug kit though.
Old May 21, 2008 | 03:25 AM
PlayPlay's Avatar
PlayPlay
Thanks for the input guys.....I still don't know which one to get. I'd like to have an air compressor that can be used for other things. But, then I can't really think of anything else I really need to inflate. I know people who autocross tend to inflate and deflate their tires regularly. I wonder if that's why people opt for the Conti or Outmotoring one, or do auto-xers buy bigger compressors for that purpose.
Old May 21, 2008 | 06:29 AM
Hubs's Avatar
Hubs
So where do the rest of you guys store your pumps and repair kits . I too am planing on getting a pump but would like to stow it securely and out of the way.
Old May 22, 2008 | 08:59 AM
RaceFace's Avatar
RaceFace
I carry 2 cans of 'fix-o-flat' and a spare in the Clubman.
Old May 22, 2008 | 06:39 PM
rwkeating's Avatar
rwkeating
Originally Posted by PlayPlay
... I wonder if that's why people opt for the Conti or Outmotoring one, or do auto-xers buy bigger compressors for that purpose.
For me the Conti is only for emergencies. I use a different pump for autox. I haven't had much luck with these little compressors lasting and I'd hate to use up the life of the Conti and not have it work when I really need it.
As far as storage, I keep it behind the drivers seat. I don't use my rear seats so its not in the way and it doesn't move around much.
Old May 22, 2008 | 06:46 PM
ENGINE 58's Avatar
ENGINE 58
look up dynaplug , i have the plug kit and a air pump. i keep it in the boot . its in a nice lil pouch. you can plug run flats with the dynaplug kit too.
Old May 23, 2008 | 07:03 PM
PlayPlay's Avatar
PlayPlay
Is there any risk in messing up one's rims using the Slime stuff?
Old May 23, 2008 | 08:05 PM
PGT's Avatar
PGT
not the rims, but the tires. they may get you home, but plan on buying a new tire.
Old May 24, 2008 | 06:39 AM
Alex@tirerack's Avatar
Alex@tirerack
ALLWAYS warn your tire tech about slime's presence so he doesn get all filthy.
Alex
Old May 24, 2008 | 09:50 AM
Robin Casady's Avatar
Robin Casady
Alex
I thought Slime was latex-based and could be washed out with water.
I've heard that Fix-A-Flat is not washable and could ruin a tire.
Old May 28, 2008 | 05:52 AM
Alex@tirerack
My ContiComfortKit has water based latex sealant that is very easy to wash out. Most "slime" kits in pressurized cans will not wash out - they are very sticky and must be scraped out.
NOTE on Metal Valve stems -If you Mini has OEM metal stems you have direct TPMS sensors inside your wheels. ANY and ALL forms of sealant will will render the sensor unusable.
Alex
Old May 28, 2008 | 06:45 AM
MirthScout's Avatar
MirthScout
It is the Fix-A-Flat and similar aerosol can sealants that glue themselves in and are very difficult to clean.
The ContiComfortKit and Slime brand sealants are both water soluable and easily cleaned.
Here's a couple of bullets from the Slime site:
Remains liquid inside the tire, coating the tread area as the tire rotates.
Non-toxic, non-hazardous, non-flammable, non-aerosol and water soluble.
Contains rust and corrosion inhibitors to maintain the integrity of the rim.
TPMS friendly (Note: May not install easily into tires with direct or valve mounted devices).
Tires treated with SLiME can be cleaned out with water allowing for the installation of a proper plug/patch.
I think the Mini valve mounted TPMS would not be as easily cleaned as implied and would probably need to be replaced. I don't have the valve mounted TPMS. The directions for Slime show using a supplied valve core removal tool, then attaching a tube to the valve stem and the Slime bottle. Then squeeze the reccommended amount of Slime into the tire. If I had the valve mounted TPMS I'd have to check to see if the valve core can be removed so you could even use Slime.
patsum
26
May 29, 2021 06:29 PM
dinomaniac
Sep 18, 2018 04:19 AM
Moya45
Sep 11, 2015 02:21 PM
Tires, Wheels & Brakes
Sep 10, 2015 03:10 PM
Panik
Sep 9, 2015 08:36 AM
